I put mine here, on the other side just to make access to it better.
I started out with it here but found it impossible to get to the connections under the dash with my gauge mounts.
![[Linked Image]](https://www.tm-img.com/images/2021/11/23/33124A0C-FD25-4FED-8476-713D20757CD8_1_105_c.jpg)
So I moved it out here so it is possible to get to all cable connections easily and the switch location.
![[Linked Image]](https://www.tm-img.com/images/2021/11/23/7AD1A62A-0173-4866-8C74-8C743BE435CE_1_105_c.jpg)
I mounted it on a hard rubber pad to isolated it from vibration a wee bit.
I have since removed it because the Tuner I was planning to use went out of business with Covid and it is not worth it to me so I settled for a locked ECU. I am sure the Emerald will produce a better Tune if you can find a Tuner t do it. I don't have those skills to Tune.
