Posts838,003
Posts: 81 |
Does anyone know if the plastic seals on the side view mirrors are available? Can’t get mine to budge while I try to swap mirrors. I may have to cut them out unless I’m missing a trick. Thanks, LarryS
Posts: 3,481 Likes: 42
Posts: 3,481 Likes: 42 |
I managed to lever mine out by inserting a small screwdriver under the edge and carefully levering it out Cheers!
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
Does anyone know if the plastic seals on the side view mirrors are available? Can’t get mine to budge while I try to swap mirrors. I may have to cut them out unless I’m missing a trick. Thanks, LarryS If all else fails, unscrew the base from the door, and you can apply extra force on the bench.
