5 members (How, B&C Morgan, bmgermany, jbk, nick w), 281 guests, and 38 robots.
+8Rich 94
John V6 50
Posts837,997
rockabilly john
Page 5 of 5 1 2 3 4 5
TBM Offline
I seem to have lost the ability to copy an image URL and paste it?
Can upload from Computer OK.
Weird! Deleted the shortcut. Googled tm image library and used that. Same result. Still incomplete loading and the in/out split still there.
Tried using private browser but still the same.
I have discovered the problem with the top menu bar.
Our version was slightly customised to show a menu item that would otherwise not display until a user logged in. This customised section did not function with the latest upgrade. As far as I can see the issue was only a problem with telephones. I could not replicate it at first because I only tried it on desktops and a tablet. I then thought to try it on my phone and saw the problem.
It also looks as though the latest version has removed the possibility of uploads from a URL. Probably a copyright infringement issue.
I have removed our customised header until I can get time to fix it so it should be working pretty much as usual now.
TM Image Library was set up independently for the use of Talk Morgan forum members
TBM Offline
Thank you
Cheers. I will have a look.
Working ok now. Just posted an image in Monday Smiles
