2 members (+8Rich, DaveK), 342 guests, and 44 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,087
Morning all, quick question. I returned from a long drive today and noticed that the right hand bolt holding the fan enclosure onto the engine had shaken loose (probably due to investigations by garage of petrol smells last week). The bolt and washer remained in place on top of the enclosure however I wonder if I have lost a spacer from under the unit? There was an almighty bang as I was driving along that I put down to running over a stone but I'm wondering if it was a lump of metal dropping off the engine.
thks
92 Connaught Green Plus 4
Triumph Bonneville 865
Yes, there should be a cylindrical alloy spacer between the fan housing and the engine block. Have a look at the way that the other housing bolt is attached as both sides are the same. The bolts should be loctited into place to prevent them coming loose - an all too common occurrence unfortunately.
Andy
Cheers Bunny. I took a look at the other side but wasn't sure if it should be identical. That would explain the big bang as the spacer must have bounced along the side of the car. Hopefully it hasn't left any holes.
I don't suppose you have any idea where to get hold of an identical spacer?
I see it listed as part number T250004 and it looks like a standard 3/8s spacer from this helpful doc. Unfortunately it doesn't give the exact size. I guess I'll just remove the other size and measure it.
https://www.mtwc.co.uk/wp-content/u...-to-fit-cooling-fan-to-Morgan-3W-min.pdf
The spacers are aluminium and are 45.5mm long, 19mm OD, ID is clearance for 3/8 inch
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Take the one remaining long sleeve spacer and have it copied by a machine shop.
I’ve had my one drop out in the past, I ordered a replacement from spares department at MMC. They will post it to you if requested
Thanks Rog that's really helpful, now I can probably find one close enough on EBay. A 3/8 bolt would clear an M10 metric ID wouldn't it?
6 mm is just shy of 1/4" .... boy I would have to actually give it a try. you also could stack up a bunch of washers
Rodger
2004 Plus 8 (wife's)
3/8 is 9.5mm so yes
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
