0 members (), 225 guests, and 60 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,761
#730244 15/01/22 12:10 PM
My car has had starting problems for a while now so I have upgraded the battery, inserted Iridium plugs and fitted the Magnacor red leads. They all needed replacing anyway so no problem there. All seemed ok but now, and this might be due to the cold, it's struggling to start again. Next thing to check is fuel pressure. First of all I am not sure if my M3W has had the fuel pump changed but whilst I find out I would like to check the fuel pressure via the Schrader valve. Can anyone recommend a reasonably priced one as it might only be ever used one.
2021 Morgan Plus Four
2012 Morgan Three Wheeler
2020 Land Rover Defender 110
Hi
I bought a fuel pump tester kit 0-140psi about £20 from ebay, works fine
PaulR
Hi Paul - Don't suppose you have a link to it?
https://www.ebay.co.uk/itm/313622751049?hash=item49055f6749:g:4zgAAOSw5hJfWfg3
PaulR
Brilliant thanks
Hi Jonathan, if you need a fuel pump I have a brand new one still in its box, just PM me if you need it.
