8 members (Morganmike, Grumpy2, DJC, Oliemog, Pyewacket, Graham, G4FUJ, Lordofthewings, Julian BB),
143
42
Topics49,911
Posts838,143
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Very cool. Which bulbs did you use? Any glare issue for oncoming traffic. i have never seen myself driving toward myself at night. I think they were the bulbs discussed previously; Amazon $45/pair.
Very cool. Which bulbs did you use? Any glare issue for oncoming traffic. ![[Linked Image]](https://www.tm-img.com/images/2022/02/04/Bulbs.png) I could not comment about light coming toward me since I am the one driving.
Posts: 1,947 |
In UK fitting LED bulbs into a headlamp reflector designed for halogen is not legal but not likely to be picked up in MOT test. Best swap out the whole bulb/reflector designed as LED. I swapped the side lights in the headlamp for LED, despite selecting LED with ceramic base one soon failed so went back to original. I changed the headlamp bulbs for uprated halogen which is an improvement
Posts: 34 Likes: 1
Posts: 34 Likes: 1 |
Stephen - thank you for you recommendation on the headlight LED bulb replacements... they make a significant difference in brightness over the halogens.
Quite easy to install as well. Plug N Play with no messy wiring or capacitors.
M3W Plus 4
Quite easy to install as well. Plug N Play with no messy wiring or capacitors. Glad it helped you. Made a big difference for me as well.
