Posts837,990
Posts: 313 Likes: 1
Posts: 313 Likes: 1 |
Many thanks for the replies. The are a number of points made that I had not considered or been aware of and this gives me food for thought. Bob.
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
I carry a Stop Lock in the pizza slot of the Roadster. I haven't used it for twenty years or so but put it on yesterday and thought that a thief would have to be very serious and need a lot of time to remove it.
Posts: 8,696 Likes: 498
Posts: 8,696 Likes: 498 |
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
This BEP marine battery isolator is of better quality than the cheapo T key car type, with a higher current rating and self cleaning contact action. I had three including the heavy duty version fitted to my last boat. The key which is very much less common can be removed after use. ![[Linked Image]](https://m.media-amazon.com/images/I/71xu3RJg3cL._AC_SL1500_.jpg)
Posts: 1,987 Likes: 104
Posts: 1,987 Likes: 104 |
Richard, many thanks for this post. I have used two "Discarnect"s with varying degrees of (un)reliability, but I'd never come across the BEP. Cheers.
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 313 Likes: 1
Thanks Richard, I’ve ordered the panel mounted version. Bob.
John re: pizza slot. Very useful and in addition to fast food, carries all my other bits and pieces. You know, all those things that you never ever need until you leave them at home.
Posts: 517 Likes: 58
Posts: 517 Likes: 58 |
I like Dirks solution to security, remove the drivers seat !!!!!
David Byrne
Posts: 318 Likes: 5
Posts: 318 Likes: 5 |
I had an isolator switch on my 4/4 when I bought it. Enough of a voltage drop across it to affect starting. So make sure the one you use is good quality.
Posts: 537 Likes: 28
Posts: 537 Likes: 28 |
David Byrne  I 've got the idea from Mr Bean but I wouldn't copy him!
Dirk
1993 Morgan +4 (Connaught Green) 2009 Mini Cooper D 2024 Mercedes GLC 1994 Ford Motorhome
