Topics49,904
Posts838,075
Posts: 263 Likes: 2
Posts: 263 Likes: 2 |
My Plus Four went to Morgan last week for it's first 3 month service. As usual a few niggles but the one that perplexes me is the clock. When I drive it at night the clock is barely illuminated. In fact so barely illuminated you can't even tell the time. I was told this is normal but surely on a car so expensive that cannot be normal. Do all of you Plus Four owners have the same problem?
2021 Morgan Plus Four 2012 Morgan Three Wheeler 2020 Land Rover Defender 110
Posts: 6,676 Likes: 441
Posts: 6,676 Likes: 441 |
i recently fitted a new Smiths analogue clock to my Mog, and the illumination is also in the 'chocolate teapot' category. At some point I need to see if I can find a brighter bulb (LED?) that's compatible. From what I remember from fitting, it is tiny and not a size I'm familiar with.
Posts: 8,701 Likes: 501
Posts: 8,701 Likes: 501 |
TBM, this is the LED version that fitted my clock ![[Linked Image]](https://www.tm-img.com/images/2019/09/16/clock-bulb.th.jpg) Of no use to Jonathan as his is a CX car and suspect difficult to access ?
Posts: 8,697 Likes: 416
Posts: 8,697 Likes: 416 |
My Plus Four went to Morgan last week for it's first 3 month service. As usual a few niggles but the one that perplexes me is the clock. When I drive it at night the clock is barely illuminated. In fact so barely illuminated you can't even tell the time. I was told this is normal but surely on a car so expensive that cannot be normal. Do all of you Plus Four owners have the same problem? If you can access behind the central clock on dash, very likely it will have a replaceable LED for illumination. Your dealer may have more info/experience. Could well be the T10 capless fittng as Jon shows above. If that proves to be the case you have a variety of illumination and colours available on eBay. Suggest going for Canbus friendly type. Changed the one on my Roadster when it blew which was a blessing because colour was way different to main instrument illumination. Interestingly the old one was LED as well despite my car only a few months older than Jon's.
Posts: 27,840 Likes: 764
Posts: 27,840 Likes: 764 |
This link ( Bulbs )might help identify the bulb, look under the technical heading. Lots on ebay. But a word of warning I did that conversion on my S1 Roadster. LEDs don't create heat so the gauges can / will mist up worse than with conventional bulbs
Posts: 263 Likes: 2
Believe it or not I don’t even think there’s a bulb. At least if there is I would have expected Morgan to have replaced it yesterday.
It could be it's integrated into the instruments electronics but surprised if there is no provision for replacement, especially as it's a separate instrument in the dash cluster.
LED illumination in general has a substancially longer service life than filament bulbs, but it's been demonstrated to me both at home and on my Morgan that poor quality LED's can give quite short service life in some cases.
Agreed Richard we are on our third LED bulb in the kitchen set of 10 or so. The oldest are 5 years old in June so well below the stated life you see on the packs. I hope the LED headlights are better.
Posts: 82 Likes: 1
Posts: 82 Likes: 1 |
I just had the same argument with the factory over my clock in my Plus Four, from. I asked if it would be possible to fit an LED from the fuel gauge, but no, the whole clock would need to be charged.
Heron Grey Plus Four 2021
Previous:- Connaught Green 4/4 1988 Black Plus 8 1998
Posts: 263 Likes: 2
