2 members (Gordon D, John Winn),
248
Posts837,997
Posts: 58 |
Still new to the Morgan venue, but learning. Is there an aftermarket solution to the doors constantly gravity closing. It sure makes getting in and out difficult. A pair of something to replace those leather straps with something positive to hold the doors open, and stay open, would be appreciated.
Posts: 6,675 Likes: 441
Posts: 6,675 Likes: 441 |
Yep, check out Librands website. Librands Door Check
Posts: 58 Likes: 2
Posts: 58 Likes: 2 |
Agreed. Worthwhile conversion.
Morgan Roadster S2 Jaguar F Pace S WW2 Jeep
Posts: 8,696 Likes: 416
Posts: 8,696 Likes: 416 |
Still new to the Morgan venue, but learning. Is there an aftermarket solution to the doors constantly gravity closing. It sure makes getting in and out difficult. A pair of something to replace those leather straps with something positive to hold the doors open, and stay open, would be appreciated. This stainless type as linked by TBM above are now fitted as OE. ![[Linked Image]](https://i.imgur.com/bKrTWDw.jpeg) They work fine in all but the strongest winds as long as you don't lubricate them. Don't ask how I know this
Posts: 1,987 Likes: 104
Posts: 1,987 Likes: 104 |
The integrity of the system depends on a good frictional fit between the PVC tube that surrounds the bolt, and the body of the stay. You may be lucky, but it may be necessary to carefully but forcefully squeeze the sides together to achieve the appropriate degree of "stiction" (there are other threads on this on TM). ![[Linked Image]](https://www.tm-img.com/images/2022/03/12/Door-stay.jpg)
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Agreed: If you e-mail Librands they will provide new plastic tube, it does wear with time, causing the doors to shut more easily.
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
Many people have said that adding these has been the most worthwhile thing that has been added to our Morgan
Posts: 58 |
Posts: 2,583 |
The Librands door checks are great and also allow the door to open wider. Incidentally, I recycled the leather stops by screwing them to the top of the inside of the door to use as a "door pull".
Posts: 58 |
How long to wait though. Been three days since I sent the inquiry.
Is this the only company that makes them?
