7 members (TalkMorgan, Hamwich, RichardV6, Image, mph, BobtheTrain, AlyMatt),
246
Topics49,914
Posts838,174
Posts: 81 Likes: 1
Posts: 81 Likes: 1 |
That’s great thanks. 😊 I found a picture of a Wanner next to a cartridge type and didn’t appreciate the size of them. I understand now 👍
Kevin Davies
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
Hand fill. Straight forward and not messy if you do it properly.
Bob
Posts: 5,608 Likes: 617
Posts: 5,608 Likes: 617 |
That's why tubs of grease have that plastic disc with a hole in on top of the contents ... you take the end off your gun, position the open barrel of the gun over the hole then press down .... squirts a column of grease straight up into your gun .... slide it sideways to nip it off at the bottom then replace the end of your gun and release the spring.
Posts: 37,490 Likes: 994
Posts: 37,490 Likes: 994 |
Yup, works well for me. Pressure it up and open the bleed screw, tighten it down again and away you go.
Posts: 502 |
Probably been asked before but I’m new to all this so can anyone advise on a good quality grease gun that I can use on my 2014 4/4 front suspension.
Thanks . All good advice here, but my advice would be to get one, which ever brand you go for that can be squeezed with one hand, a bit like you do with a mastic gun.
2004 Series 1 Roadster
Posts: 1,245 Likes: 2
Posts: 1,245 Likes: 2 |
Another +1 for a Wanner but fitted with a flexible hose which makes greasing a Morgan much easier.
Posts: 172 |
Re filling gun, first you twist large black knob at base of cylinder and pull on chain to take pressure off sprung plate before placing over filler plate in grease tub. Check that the tub of grease has the disc with a hole in, not all makes do. On my Wanner gun (purchased in 1973, chrome plating now worn through) I have swopped the nozzle over to the alternative position to make a straight rather than 90 degree gun.
Jack 1985 4/4 T/C 4 seater Royal Ivory 1934 F Type 2018 Pembleton SuperSport (self built).
Posts: 6,678 Likes: 441
Posts: 6,678 Likes: 441 |
Check that the tub of grease has the disc with a hole in, not all makes do.. Yeah, the "red n tacky" doesn't, hence the spoon method
Posts: 172 |
Swopping the disc from another tub is easier than using a spoon!
Posts: 81 Likes: 1
Amazing information guys thank you all so much for the help and advice 👍
Kevin Davies
