8 members (John V6, KennethM, Dek, thelastgizmo, Image, JMcL, Lance, Luddite), 310 guests, and 38 robots.
+8Rich 101
John V6 62
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,195
Georgetoad, woolfie
Alpha1 Offline OP
That’s great thanks. 😊
I found a picture of a Wanner next to a cartridge type and didn’t appreciate the size of them.
I understand now 👍
Kevin Davies
Hand fill. Straight forward and not messy if you do it properly.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
That's why tubs of grease have that plastic disc with a hole in on top of the contents ... you take the end off your gun, position the open barrel of the gun over the hole then press down .... squirts a column of grease straight up into your gun .... slide it sideways to nip it off at the bottom then replace the end of your gun and release the spring.
Yup, works well for me.
Pressure it up and open the bleed screw, tighten it down again and away you go.
Originally Posted by Alpha1
Probably been asked before but I’m new to all this so can anyone advise on a good quality grease gun that I can use on my 2014 4/4 front suspension.
Thanks .
All good advice here, but my advice would be to get one, which ever brand you go for that can be squeezed with one hand, a bit like you do with a mastic gun.
2004 Series 1 Roadster
Another +1 for a Wanner but fitted with a flexible hose which makes greasing a Morgan much easier.
Re filling gun, first you twist large black knob at base of cylinder and pull on chain to take pressure off sprung plate before placing over filler plate in grease tub.
Check that the tub of grease has the disc with a hole in, not all makes do.
On my Wanner gun (purchased in 1973, chrome plating now worn through) I have swopped the nozzle over to the alternative position to make a straight rather than 90 degree gun.
Jack
1985 4/4 T/C 4 seater Royal Ivory
1934 F Type
2018 Pembleton SuperSport (self built).
TBM Offline
Originally Posted by Jack & Jill 602
Check that the tub of grease has the disc with a hole in, not all makes do..
Yeah, the "red n tacky" doesn't, hence the spoon method smile
Swopping the disc from another tub is easier than using a spoon!
Jack
1934 F Type
Alpha1 Offline OP
Amazing information guys thank you all so much for the help and advice 👍
Kevin Davies
