2 members (Soleng, Plus Four Guy), 271 guests, and 42 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,088
Leroy Offline OP
Thanks for the advice guys. Looks like it need to investigate my lock first and go from there.
2004 Series 1 Roadster
Leroy Offline OP
So, from the above images, there is already a square rod protruding out of the correct side, but stops 1-2mm short of the door skin. This square rod goes into the lock and connects to the handle on the inside. Other than glueing anotjer square rod to the existing one, giving it extra length to enter the external handle, what options are available. Thanks
Buy a new lock designed to have a handle I guess. I wouldn't bother, my first car had no door handles it wasn't an issue.
Leroy Offline OP
Actually, having looked at the door handle in mogparts, there is a part that would protrude through the door skin and would most likely fit into the square rod, so I think I have answered my own question. Was relatively simple to remove the lock earlier so this is well within my capabilities.
Hi Leroy,
Usually the handle (shank) goes through the rose and is secured to it by a circlip. The shank is not flush with the rose back, it will protrude about 8mm and will have a square hole to accommodate the spindle. Obviously you need a larger hole in the door to accommodate the shank. Best of luck.
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Leroy Offline OP
Originally Posted by SALMO
Hi Leroy,
SALMO, yes, from looking at the images I took and on mogparts, that would seem correct. Thanks
As shown here in Mogparts listing.
Presumably the part that protrudes through the skin has a female square section to match and engage with the door lock square shaft. A quick phone call would confirm this.
Hi
I am new to the forum and own a plus 4 1997 Rover T16, i would like to post a question about a bottom crank pulley topic, can you guide or assist me please
thanks Jason
TBM Offline
Originally Posted by JasonB
Hi
thanks Jason
You're in the right section - clicking on Maintenance and Servicing (at the top of the page), and then on 'New Thread' and you can start your own.
Hi
thanks Jason
Welcome Jason. Suggest starting a new thread in the Maintenance & Servicing section, click here. You will then see the option "New Thread" towards the top left. Click on this, add a title then ask your question.
