7 members (RedThree, Davetherave, Grumpy2, Craig Jezz, Aeromax51, Socalm3w, Gambalunga),
257
Topics49,911
Posts838,145
Posts: 502 |
Thanks for the advice guys. Looks like it need to investigate my lock first and go from there.
2004 Series 1 Roadster
Posts: 502 |
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
Buy a new lock designed to have a handle I guess. I wouldn't bother, my first car had no door handles it wasn't an issue.
Posts: 502 |
Actually, having looked at the door handle in mogparts, there is a part that would protrude through the door skin and would most likely fit into the square rod, so I think I have answered my own question. Was relatively simple to remove the lock earlier so this is well within my capabilities.
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Hi Leroy, Usually the handle (shank) goes through the rose and is secured to it by a circlip. The shank is not flush with the rose back, it will protrude about 8mm and will have a square hole to accommodate the spindle. Obviously you need a larger hole in the door to accommodate the shank. Best of luck.
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 502 |
Hi Leroy, Usually the handle (shank) goes through the rose and is secured to it by a circlip. The shank is not flush with the rose back, it will protrude about 8mm and will have a square hole to accommodate the spindle. Obviously you need a larger hole in the door to accommodate the shank. Best of luck. SALMO, yes, from looking at the images I took and on mogparts, that would seem correct. Thanks
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
As shown here in Mogparts listing. ![[Linked Image]](https://mogparts.net/thumbnails/userfiles/files/CRM094%282877%29_500x500cc.JPG) Presumably the part that protrudes through the skin has a female square section to match and engage with the door lock square shaft. A quick phone call would confirm this.
Posts: 2 |
Hi
I am new to the forum and own a plus 4 1997 Rover T16, i would like to post a question about a bottom crank pulley topic, can you guide or assist me please thanks Jason
Posts: 6,676 Likes: 441
Posts: 6,676 Likes: 441 |
Hi
I am new to the forum and own a plus 4 1997 Rover T16, i would like to post a question about a bottom crank pulley topic, can you guide or assist me please thanks Jason You're in the right section - clicking on Maintenance and Servicing (at the top of the page), and then on 'New Thread' and you can start your own. ![[Linked Image]](https://tm-img.com/images/2022/04/18/new-thread.md.jpg)
Hi
I am new to the forum and own a plus 4 1997 Rover T16, i would like to post a question about a bottom crank pulley topic, can you guide or assist me please thanks Jason Welcome Jason. Suggest starting a new thread in the Maintenance & Servicing section, click here. You will then see the option "New Thread" towards the top left. Click on this, add a title then ask your question.
