Morgan Aero 8
5 members (JohnHarris, TBM, MartO, BobtheTrain, sospan), 231 guests, and 29 robots.
+8Rich 96
John V6 51
Topics49,899
Posts838,027
#737847 02/04/22 06:06 PM
Peter J Offline OP
Formerly known as Aldermog
On Friday the radiator level warning light came on when I started the car. After a few minutes it went out.
Today I checked the level in the header tank, sure enough it was at, or below, the lower level mark.
I had a bottle of BMW Antifreeze, so topped the system up.
I'll keep a close eye on this as the BMW N62B48 motor has a "known weakness" in that a coolant transfer pipe that runs in the "V" of the engine under the inlet system can start to leak from the "O" rings that seal the pipe to the cylinder block: there are lots of posts about this on US BMW forums. Water dribbles down on to the garage floor.
Repair is very costly in time....if the official BMW procedure is used as it requires a partial engine strip down, removing all the front end including cam chains: 2 days labour.... !!
A number of aftermarket solutions exist that are based on cutting out the pipe and fitting a new one that is in 2 parts.
Here is one..
https://www.pelicanparts.com/techar..._8_Cylinder_Coolant_Pipe_Replacement.htm
And here is a post from a UK BMW Specialist...
http://www.munichpower.co.uk/bmw-and-mini-blog/n62-water-transfer-pipe-failure/
In the meantime I'll buy a new bottle of antifreeze...and watch the garage floor....!
Peter J #737850 02/04/22 06:10 PM
PJC Offline
Hi Peter,
Good idea to check with MMC what Antifreeze as I had a water leak and used BMW antifreeze only to be told by Brands Hatch Morgan that the antifreeze specified by MMC and used was very different and not compatible - I had to get the car trailered to BHM to have it drained and the correct stuff added! I had no idea how critical the correct antifreeze was. ooo
Cheers, Paul
Peter J #737854 02/04/22 06:15 PM
Peter J Offline OP
Thanks for the warning...
Why on earth would MMC use their own antifreeze, not BMW specified material?
The BMW stuff is blue.
PJC #737856 02/04/22 06:34 PM
Originally Posted by PJC
Hi Peter,
Allegedly if some non compatible types are mixed it forms gelatinous lumps that can block small internal waterways on modern engines
Peter J #737859 02/04/22 06:42 PM
Here is one..
It looks like the 'telescopic' replacement pipe introduces more O rings & will these later fail ?
I would think Simon at SiFab will have come across this issue before, may be worth a chat, Peter ?
Peter J #737879 03/04/22 06:38 AM
Does anyone know what the correct stuff is called?
Porsche 981 Spyder
V8 Speedster ( 5 years)
4/4 Competition spec (5 years)
4/4 4str Kent ( 10 years)
Peter J #737893 03/04/22 09:08 AM
According to the handbook the correct coolant should be:
‘Water/Antifreeze mixture 50/50 longlife spec with corrosion inhibitor for aluminium engines all year round’
But what if you’re far from home and don’t have a ready supply of the exact mix to hand?
The advice I’ve been given is if your warning light comes on during the warmer months and you're not able to determine which coolant is already in your engine - top up with distilled water (this will naturally dilute the volume of antifreeze.) And before winter comes flush out your system and reload with the correct mix.
2016 Aero 8 S5
Peter J #737895 03/04/22 09:23 AM
Peter J Offline OP
There are two types of antifreeze, IAT and OAT and they don't get on well, so we need to know what MMC uses....
Yes, I'll ask Simon.
Peter J #737896 03/04/22 09:31 AM
TBM Online Content
Don't forget HOAT, P HOAT and Si - OAT smile
Valvoline do a good guide. Older kit like mine uses IAT (I think OAT causes issues with the block).
Valvoline
Peter J #737902 03/04/22 10:28 AM
You are scaring me... Let me follow this while I keep my fingers crossed.
