6 members (JMcL, SEG, BobtheTrain, Zach, MartO, CooperMan), 233 guests, and 22 robots.
+8Rich 96
John V6 51
Topics49,902
Posts838,049
Page 3 of 3 1 2 3
Originally Posted by DaveW
That's a really neat installation.
I must admit a pressure gauge and voltmeter are very tempting.
Dave, I'm on it... see my idea about VDO gauges
Thanks Simon. It would seem a lot has to come off to get to the oil pump & relief valve on the sigma. My pressure is indicating some of the time 5bar @ 3000 rpm & waivers a bit. I’ll try a new sender 1st.
You should note that those oil pressure transmitters are mediaeval in their design. I pulled one to pieces, it's basically rheostat with wiper arm operated by a system of levers.... archaic! The on the other hand ive got installed now seems to somewhere near, +/- 15% on a good day. Installing one could cause you more consternation than you need. Ive had a normal bourden tube gauge that i knew to be accurate to within about +/-10%. But hey, it keeps the car complete. Dave, do you cars not have oils pressure indication?
By the way I did install an oil temperature gauge, the sender I installed an tapping already present in the Raceline sump although I installed a 2nd transmitter up near the pressure take off with option to use. Mine's the Mazda MZR engine by Omex, as per the Plus 4 SS, but to all intents and purposes a Ford Duratec.
My Roadster has oil pressure and voltmeter, but the GDI has neither.
The most entertaining gauge I ever had was a Smith's vacuum gauge which a previous owner had fitted to my 67 Midget. How I miss that dancing needle even now, and that was 1972 or thereabouts
Page 3 of 3 1 2 3
