0 members (),
326
36
Topics49,897
Posts838,017
Posts: 1,415 |
The revised radiator mounting, along with the lower pressure cap, and reduced coolant level has not prevented any further radiator failures
I’ve been contacted by a dealer , who having fitted a third replacement radiator on a Plus Six in year, had the third radiator last less than 80 miles….
I’ll be working on a solution soon….
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 5 |
I changed my leaky radiator With replacement, new cap and 50% full fluid I have done 2500 kms since, without problem ... for the moment ...
Fun is not a straight line ...
Posts: 8,696 Likes: 416
Posts: 8,696 Likes: 416 |
I’ll be working on a solution soon…. Not a minute too soon by the sound of it Simon. You will have a strong market for such I'm sure. FWIW it's taken me a couple of months and a 1000 miles to completely cure minor hose leaks on my Roadster which despite nipping up hose clips when hot, kept re-appearing and in differing locations including T piece, top and bottom hose. Finally cured by extra hose clips on the lower two of bottom hose connections and ensuring coolant filled to no higher than mid mark on header tank.
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
Lets hope so Richard I know Hawki's new to him plus four has had 4 rads in 18 months.
Posts: 31 Likes: 11
Posts: 31 Likes: 11 |
I had a major leak on my radiator which was very efficiently replaced by Adam at MelvynRutter (under warranty) - this seems to have fixed the leaking. To answer John V6’s question about the engine coolant cap being changed - attached are some photos - the original cap has a red “Stant” printed on it, the new cap has no such printed text. When the cap is replaced the header tank is drained and refilled with 500ml of coolant (and a sticker applied to the side of the tank). No idea if these two things will permanently fix the radiator blowing again, but I hope they will! Old cap as installed (note there is a second similar tank and cap, just visible under hood - that is the aircon coolant): ![[Linked Image]](https://i.ibb.co/wrr0pF4/7093-CA3-F-C848-4-F9-A-ACE1-7346-ED947-B09.jpg) New cap: ![[Linked Image]](https://i.ibb.co/hFGp8hX/54-DB8916-AEF4-4-F04-B56-D-337144910-C07.jpg) ![[Linked Image]](https://i.ibb.co/ydKcD3v/82-B39-CA6-CC77-476-E-8-BD2-4194-FF03-EAB7.jpg) New cap and sticker installed: ![[Linked Image]](https://i.ibb.co/BCGCDhr/20-ECB7-C3-1299-4-F12-9360-5854-F4-C2-B030.jpg)
Posts: 665 Likes: 31
Posts: 665 Likes: 31 |
Strangely , after i had again a leak with le third radiator and the new cap , no drops on the garage floor even i have made two times 350 km .
Posts: 1,415 |
I had a major leak on my radiator which was very efficiently replaced by Adam at MelvynRutter (under warranty) - this seems to have fixed the leaking. To answer John V6’s question about the engine coolant cap being changed - attached are some photos - the original cap has a red “Stant” printed on it, the new cap has no such printed text. When the cap is replaced the header tank is drained and refilled with 500ml of coolant (and a sticker applied to the side of the tank). No idea if these two things will permanently fix the radiator blowing again, but I hope they will! Old cap as installed (note there is a second similar tank and cap, just visible under hood - that is the aircon coolant): ![[Linked Image]](https://i.ibb.co/wrr0pF4/7093-CA3-F-C848-4-F9-A-ACE1-7346-ED947-B09.jpg) New cap: ![[Linked Image]](https://i.ibb.co/hFGp8hX/54-DB8916-AEF4-4-F04-B56-D-337144910-C07.jpg) ![[Linked Image]](https://i.ibb.co/ydKcD3v/82-B39-CA6-CC77-476-E-8-BD2-4194-FF03-EAB7.jpg) New cap and sticker installed: ![[Linked Image]](https://i.ibb.co/BCGCDhr/20-ECB7-C3-1299-4-F12-9360-5854-F4-C2-B030.jpg) The second tank is for the chargecooler not aircon
Simon @ Sifab.co.uk
Posts: 1,987 Likes: 104
Posts: 1,987 Likes: 104 |
I'm intrigued by this discussion (although I don't have a problem with my Roadster radiator as far as I know), because I have previously owned TVRs which featured a "swirl tank" (or "swirl pot"). This article explains: https://www.merlinmotorsport.co.uk/...system-header-tanks-in-your-race-car-323I recall there was some discussion among TVR owners as to which of the caps should be "pressure relief" type, and which simply plain. In my last TVR, an S3, also with a Ford V6 (2.9) engine, I had a swirl pot with a pressure-cap above the thermostat. The overflow just had a cap, as the level never reached more than about half. This is probably all basic stuff for somebody who knows more than me about Morgan cooling systems, and will probably be able to explain which of our cars if any have swirl pots. ![[Linked Image]](https://www.tm-img.com/images/2022/05/26/S3-engine-bay-showing-swirl-pot-and-overflow-with-caps-2.jpg)
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Yes Jon, that's what these boys said as per dealers advise.. So, as I see it a WET system that becomes hydraulically locked by it's OE design...and blows things apart...  I don't see it as a hydraulic lock situation Jon. The coolant vapour pressure above the level in the header tank reflects back through the incompressible coolant to pressurise the radiator. Increasing this vapour volume with lower coolant level and futher controling it's pressure with release cap was supposedly the radiator fix. I understand CX rads have still failed after this though
Posts: 208 Likes: 7
Posts: 208 Likes: 7 |
I wonder if it is not a quality problem of the radiators. Mine at 12,000 km.
We changed the cap and checked the level at 8000 KM. We drove around Spain with a temperature of 35°C and not a drop under the car.
Uneven manufacturing quality may be the explanation.
