0 members (), 254 guests, and 45 robots.
+8Rich 101
John V6 57
Topics49,911
Posts838,152
Georgetoad, woolfie
#740687 02/05/22 12:57 AM
Dutch Offline OP
Is there a +8 owner's manual on line somewhere ?
I've done a search here and not had any luck.
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
I suspect gomog.com is about the nearest to, and better than, a workshop manual you can find, be that on line or anywhere else..? I think the MMC`s best attempt at providing information was with whatever handbook came with the car and which could be found not to apply to the Morgan, it was more a generic guide... I guess in the early days Morgans were simple enough machines and generally bought by those who couldcarry out repairs and modifications themselves..... Times change..!
Hope you find the info you need, but if not there is a considerable knowledgebase on here that is ever eager to help out.
Good luck in your search.. thumbs
MMC did replacement manuals when i got my 97 +4 probably 8 years ago. This was the thin handbook that came with the car.
Smile, it confuses them
Someone from the forum shared this on line parts guide to the Aero Coupe and Supersports a long time ago. As many parts are common it may provide some assistance.
https://www.aero-racing.co.uk/partsbooks/supersports/front.susp.htm
(Whoops sorry, made assumption of Aero Plus 8)
Melvyn Rutter had reprints of various handbooks. I think the MSCC may have done so also?
Dutch, if you are stuck I'll scan my 1999 Plus 8 Handbook in and send it to you if you drop me a PM with an email address - this system can't cope with pdf format being the reason.
With this and the appropriateHaynes Manual covering the engine and gearbox it's all you need really mine is for the LR Discovery but yours being a little earlier would probably be a Range Rover one.
Your gearbox I think will be the LT77 and rear axle a Salisbury unit gomog have some information on the cars too but you need to be selective at times with the information as it has been found to be in error over the years..
There are very few questions that remain unanswered on TM of a technical nature, the wealth of knowledge on here is extraordinary and all given willingly, someone has always come across the problem before and it amazes me time and time again.
Here’s a Gomog link
https://www.gomog.com/allmorgan/Hints&HandbooksIndex.html
I will check my files as I think I might have a spare. It would be for a 2002 Plus8 if I still have it.
Dutch Offline OP
Thanks for the link to gomog. I found the correct + 8 manual there.
Talk Morgan rocks !
What a great group.
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
