2 members (+8Rich, bmgermany), 226 guests, and 37 robots.
+8Rich 95
John V6 52
Posts838,003
rockabilly john
Page 2 of 4 1 2 3 4
Can Plus 8's of that era suffer fuel vapour lock ? Some say that the higher ethanol content doesn't help either
Take a look at gomog idle issues idle issues I started to experience similar issues and read this article, changed stepper motor for around £30 and all good. Have spent some time cleaning up the old one and will keep it as a spare.
stepper bought here
Hope this helps
Silver Morgan +8 " The Duchess"
'69 Triumph Bonneville
Life is a journey, best traveled in a Morgan
lumpy #741179 06/05/22 09:08 PM
Thank
stepper bought here
Hope this helps
Thank you!
Mike H
Bourgogne Franche Comté
One simple diagnostic. Turn the ignition on, don't try to start, can you hear the fuel pump run for a few seconds. If you can it means that the fuel pump and relay are good.
As the engine was running before you turned the ignition off, it suggests that there is something affected by the heat that no longer works under the lower voltage present while cranking the engine.
One item not mentioned so far is the pickup in the distributor. I suffered for a long time with an occasional failure to start. Tried all of the items listed already. Eventually, while down in Cornwall with a failure to start, I checked the gap between the sensor and the toothed rotor. Just used a piece of very thin card to judge the gap. Not sure if it was the effect of the card cleaning the edge of the sensor, or me closing the gap, but problem was cured. As your engine was running before you turned the ignition off I guess the sensor (pickup) coil is OK (no breaks) otherwise you would have experience running issues, could be the output signal from the sensor is too low for the ignition amp when cranking the engine.
The one item that has caused me most issues is the rotor arm, just had to change one again, the quality of new ignition parts is a bit of a lottery, have even had one that wouldn't fit on the distributor shaft, and a cap that wouldn't sit on the distributor.
Mike Smith
2007 +4
Thanks Mike
Fuel pump and relay are fine, as you suggest something does not like the heat. I’ve put my spare new coil on and will test it this week, I’ve also ordered a fuel temp sensor from the UK, so unlikely to see that until the end of the week. I’m now trying to find a stepper motor that isn’t Britpart…
Mike H
Mick, I would suggest you get a copy of Rover Gauge and the correct lead. Think they’re about £35 from eBay. It’s really the only way to interrogate your ecu and will help identify problems. It works on a windows pc platform and is a bit ‘clunky’ but better that stabbing in the dark.
This is a screen shot.
You also gat an indication of fault codes and can clear them too. Here an old screen shot of mine.
I keep my lead connected and tucked up out of the way - easier than trying to connect it as access isn’t too easy.
Cheers.
Gary
A run out to Maçon today confirms it’s not a coil problem, it died three times on the way back, twice whilst slowing for roundabouts, something it’s not done before.
I’m still trying to find a non-Britpart fuel temp sensor - can’t find an EAC one in stock anywhere, so still looking.
Mike H
Do you know the fault codes that the ECU will be showing, that can help you narrow your search for the problem?
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Mike, have you tried the ignition amplifier?
David Byrne
B3MOG #741891 14/05/22 07:01 PM
David Byrne
It’s a new one, done a couple of thousand miles, I’ll try refitting the old one though, thanks David
Mike H
Page 2 of 4 1 2 3 4
