12 members (John V6, IcePack, JohnHarris, Chris Cosher, GrumpyPa, +8Rich, Graham, G4FUJ, MartinB60, RichardV6, High Hamster, Morganmike, TalkMorgan), 299 guests, and 35 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,092
Dutch #741745 12/05/22 08:28 PM
Dutch Offline OP
I've ordered a smaller steering wheel so that should give me the clearance I need. I'm still looking at lowering the seat.
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
Dutch #741831 13/05/22 06:32 PM
I had a 1959 Aston some years ago that I struggled to get my athletic frame in an out of. So I had a removable steering wheel fitted, which made life much easier. Might be a solution?
+8 4.8
Dutch #741858 14/05/22 10:25 AM
Re the securing of the bolt heads...I would have fitted socket head bolts if I had the right size. An Allen key or similar socket would make it easy then. Luckily the small Stilson was ideal.
Dutch #741863 14/05/22 11:16 AM
I normally use needle nose Mole Grips but have also seen screwdriver slots cut into bolt heads, not deep and doubt it compromised strength as they only need to be held lightly as once the nut torque comes on they hold tight anyway.
BR
Colin
BR Colin
sospan #741872 14/05/22 02:33 PM
This is what I ended up doing, using M8 socket head bolts. Before that I took a Forstner bit to the wooden rails and cut out enough so I could secure the bolt to the rail with a nut that would then sit inside the pocket so created. Then it was a matter of lowering the seat onto the rails so the protruding bolts would go through the holes in the floor. Although this worked well for tightening, it was a bit of a faff to get the bolts to line up, hence the move to the socket heads.
Dutch #741885 14/05/22 05:42 PM
Dutch Offline OP
Thanks for all the info. I'm going to see how much more clearance I get with the 13" steering wheel. If it's not enough it's off to lower the seats.
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
Dutch #742042 16/05/22 04:58 PM
Dutch Offline OP
I opted to get a smaller steering wheel. I looked at a lot of different places and most were around $ 300 USD. So I went to my go to place Amazon.
I got the wheel I wanted for $ 150 and it's a perfect fit. Looks exactly like the old wheel. Took 10 minutes to swap it out with the old wheel.
Now the steering wheel doesn't hit my legs anymore and I can actually easily get in and out of the car.
https://www.amazon.com/gp/product/B079QR4ZSW/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
