1 members (Alan Patterson),
210
Posts837,998
Posts: 8,696 Likes: 498
Posts: 8,696 Likes: 498 |
Can Plus 8's of that era suffer fuel vapour lock ? Some say that the higher ethanol content doesn't help either
Posts: 59 |
Take a look at gomog idle issues idle issues I started to experience similar issues and read this article, changed stepper motor for around £30 and all good. Have spent some time cleaning up the old one and will keep it as a spare. stepper bought hereHope this helps
Silver Morgan +8 " The Duchess" '69 Triumph Bonneville
Life is a journey, best traveled in a Morgan
Posts: 203 Likes: 8
Posts: 203 Likes: 8 |
Thank Take a look at gomog idle issues idle issues I started to experience similar issues and read this article, changed stepper motor for around £30 and all good. Have spent some time cleaning up the old one and will keep it as a spare. stepper bought hereHope this helps Thank you!
Mike H Bourgogne Franche Comté
Posts: 322 Likes: 3
Posts: 322 Likes: 3 |
One simple diagnostic. Turn the ignition on, don't try to start, can you hear the fuel pump run for a few seconds. If you can it means that the fuel pump and relay are good.
As the engine was running before you turned the ignition off, it suggests that there is something affected by the heat that no longer works under the lower voltage present while cranking the engine.
One item not mentioned so far is the pickup in the distributor. I suffered for a long time with an occasional failure to start. Tried all of the items listed already. Eventually, while down in Cornwall with a failure to start, I checked the gap between the sensor and the toothed rotor. Just used a piece of very thin card to judge the gap. Not sure if it was the effect of the card cleaning the edge of the sensor, or me closing the gap, but problem was cured. As your engine was running before you turned the ignition off I guess the sensor (pickup) coil is OK (no breaks) otherwise you would have experience running issues, could be the output signal from the sensor is too low for the ignition amp when cranking the engine.
The one item that has caused me most issues is the rotor arm, just had to change one again, the quality of new ignition parts is a bit of a lottery, have even had one that wouldn't fit on the distributor shaft, and a cap that wouldn't sit on the distributor.
--------------------------- Mike Smith
2007 +4
Posts: 203 Likes: 8
Thanks Mike Fuel pump and relay are fine, as you suggest something does not like the heat. I’ve put my spare new coil on and will test it this week, I’ve also ordered a fuel temp sensor from the UK, so unlikely to see that until the end of the week. I’m now trying to find a stepper motor that isn’t Britpart…
Posts: 1,464 Likes: 99
Posts: 1,464 Likes: 99 |
Mick, I would suggest you get a copy of Rover Gauge and the correct lead. Think they’re about £35 from eBay. It’s really the only way to interrogate your ecu and will help identify problems. It works on a windows pc platform and is a bit ‘clunky’ but better that stabbing in the dark. This is a screen shot. ![[Linked Image]](https://www.tm-img.com/images/2022/04/29/C7893C27-4724-4C27-95E2-5EBD774A02EC.jpg) You also gat an indication of fault codes and can clear them too. Here an old screen shot of mine. ![[Linked Image]](https://www.tm-img.com/images/2020/10/17/9251E5D0-B0C4-4276-AE4B-938F95F638A3.jpg) I keep my lead connected and tucked up out of the way - easier than trying to connect it as access isn’t too easy. Cheers. Gary
Posts: 203 Likes: 8
A run out to Maçon today confirms it’s not a coil problem, it died three times on the way back, twice whilst slowing for roundabouts, something it’s not done before.
I’m still trying to find a non-Britpart fuel temp sensor - can’t find an EAC one in stock anywhere, so still looking.
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
Do you know the fault codes that the ECU will be showing, that can help you narrow your search for the problem?
Posts: 517 Likes: 58
Posts: 517 Likes: 58 |
Mike, have you tried the ignition amplifier?
David Byrne
Posts: 203 Likes: 8
David Byrne It’s a new one, done a couple of thousand miles, I’ll try refitting the old one though, thanks David
