5 members (John V6, Chris Cosher, jbk, RichardV6, bmgermany), 311 guests, and 39 robots.
+8Rich 96
John V6 51
Topics49,899
Posts838,024
#742926 26/05/22 04:53 PM
The mats in my 3 Wheeler are a pain in the ar5e so am mulling over sorting some in chequer plate. Firstly does anyone sell these and secondly if I do my own what thickness should I use?
2021 Morgan Plus Four
2012 Morgan Three Wheeler
2020 Land Rover Defender 110
I'm quite happy with my Coco mats - they fit well and stay put.
I agree - the Coco Mats are great!
Scott
2018 M3W
1995 Porsche 993
Mine work perfect. The only one teasing me was the one just in front of the pedals, where i put my ankles. I fixed that one with Velcro adhesive tape. High quality and hard ones from 3M. It doesn't move at all now. And I can pull it up and th Velcro stays in place.
www.speedymarmots.com
I use velcro too, works wonders on a lot of things needing to be held in place.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Jonathan
1.5 - 2.0 mm will be plenty thick enough, find a local metal fabricator, they will cut them to size for you - take good measurements or make some cardboard templates.
Mike H
Bourgogne Franche Comté
I used 1mm thick aluminium sheet on the mat near the pedals. Bought from diy chain B&Q.
I used pop rivets with washer backing to fix it. Been in place for a few years and still ok.
It was mk2 as mk1 was a bit small and I kept catching my heel on the edge.
The 1mm thick is flexible enough to form in other areas too.
Also think about the water ingress! Our 3-Wheelers can take a lot of water if you're caught under heavy rain! And having water and humidity between two metal plates.... it's not a good idea. Rust will appear sooner than later! gloomy
I have had 3mm ally chequer plate on coco mats for many years now with no issues[Linked Image]
As usual thank you for all of the input. I have ordered some chequer plate. Hadn't thought about the metal to metal thing but now I know I'll sort
