Topics49,897
Posts838,018
Posts: 263 Likes: 2
Posts: 263 Likes: 2 |
The mats in my 3 Wheeler are a pain in the ar5e so am mulling over sorting some in chequer plate. Firstly does anyone sell these and secondly if I do my own what thickness should I use?
2021 Morgan Plus Four 2012 Morgan Three Wheeler 2020 Land Rover Defender 110
Posts: 439 Likes: 3
Posts: 439 Likes: 3 |
I'm quite happy with my Coco mats - they fit well and stay put.
Posts: 101 |
I'm quite happy with my Coco mats - they fit well and stay put. I agree - the Coco Mats are great!
Scott
2018 M3W 1995 Porsche 993
Posts: 960 Likes: 21
Posts: 960 Likes: 21 |
Mine work perfect. The only one teasing me was the one just in front of the pedals, where i put my ankles. I fixed that one with Velcro adhesive tape. High quality and hard ones from 3M. It doesn't move at all now. And I can pull it up and th Velcro stays in place.
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
I use velcro too, works wonders on a lot of things needing to be held in place.
Posts: 203 Likes: 8
Posts: 203 Likes: 8 |
The mats in my 3 Wheeler are a pain in the ar5e so am mulling over sorting some in chequer plate. Firstly does anyone sell these and secondly if I do my own what thickness should I use? Jonathan 1.5 - 2.0 mm will be plenty thick enough, find a local metal fabricator, they will cut them to size for you - take good measurements or make some cardboard templates.
Mike H Bourgogne Franche Comté
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
I used 1mm thick aluminium sheet on the mat near the pedals. Bought from diy chain B&Q. I used pop rivets with washer backing to fix it. Been in place for a few years and still ok. It was mk2 as mk1 was a bit small and I kept catching my heel on the edge. The 1mm thick is flexible enough to form in other areas too.
Also think about the water ingress! Our 3-Wheelers can take a lot of water if you're caught under heavy rain! And having water and humidity between two metal plates.... it's not a good idea. Rust will appear sooner than later!
Posts: 1,562 |
I have had 3mm ally chequer plate on coco mats for many years now with no issues ![[Linked Image]](https://www.tm-img.com/images/2022/05/27/matting.jpg)
Posts: 263 Likes: 2
As usual thank you for all of the input. I have ordered some chequer plate. Hadn't thought about the metal to metal thing but now I know I'll sort
