7 members (John Wilcox, Morganmike, BLUE+4, Jon G4LJW, cerealsurfer, MATTMOG, Graham, G4FUJ),
215
43
Topics49,901
Posts838,042
Posts: 27,839 Likes: 764
Posts: 27,839 Likes: 764 |
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Thanks for the info Mike, I've squirrelled it away. Oddly, I thought your breakages were going to be at the prong area 'cos there's a lot of friction to be dealt with there. So, thanks for advising this potential problem and fix. Are you taking orders 'cos it looks very professional?!
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 322 Likes: 3
Posts: 322 Likes: 3 |
At first I made the plates from 3mm thick aluminium thinking that that would add strength, but realised that the surface of the rail isn't flat, but profiled (or maybe uneven is a better word), so I used 1mm steel so it will take the shape of the surface when all tightened up. The original fixing screws are 6mm, I used 5mm for the screws that fix the plate to the rear part of the rail so as not to weaken the rail too much. So I can always supply a drawing/template as I have a set in aluminium Decided to buy a stapler which uses 140 staples (10mm flat crown) to fit the cloth trim back in place. and unibond repair extreme power glue to stick the rubber back to the rail
--------------------------- Mike Smith
2007 +4
