7 members (Goldman, Graham, G4FUJ, Guten, SailingTom2, Ian Wegg, DavidR, TBM), 275 guests, and 27 robots.
+8Rich 96
John V6 51
Topics49,899
Posts838,021
IcePack #745358 21/06/22 03:14 PM
+1 for the dremmel, it's surprising how good they are with a little patience.
2004 Series 1 Roadster
IcePack #745369 21/06/22 04:28 PM
IcePack Offline OP
Thanks for the info. Yes I cut the slot for a screw driver with a Dremel. Image, when you say go to the end of the bolt & cut straight down. Do you mean continue the screw driver slot I made? I do have a full size grinder as well as the Dremel.
My idea is to replace the present bolt & nut with a marine grade stainless cap head bolt & marine grade nyloc. Hopefully all will then easily undo allowing me to raise the tank and replace 2 of the planks. At a later date will do the front plank that is not rotten, as it is restricted by the panhard. Need to get the car higher for that. By the way am using Accoya for replacement.
The tie strip nuts came loose no problem.
ChrisP #745380 21/06/22 05:03 PM
Originally Posted by ChrisP
If access is restricted you could use a Dremel with a metal cutting disc. It’s surprising how effective they are.
Agreed, but please wear some safety specs chaps, those thin Dremel discs break very easily and ping bits in your eyes, very nasty
IcePack #745388 21/06/22 05:39 PM
My Troop Sergeant in the Royal Marines was a Nut Splitter.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Budster #745405 21/06/22 07:15 PM
Originally Posted by Budster
Replaced around 500 fixings on my Land Rover without using nut splitter. The worst old ones just sheared given enough purchase. Admit I may have ground the heads of one or two though.
Wouldn't dream of re-using old fixtures, all mine replaced with stainless.
Many years ago, I was warned not to replace some of the fixings (on a motorbike) with stainless, due to their inherent lower tensile strength.
This might or might not be true, but that warning has always been at the back of my mind.
Hopefully a wise TMer will be able to advise!
Bud
4/4 - Stanley
:budsterr
It is generally true and I wouldn't dream of using them on engine or suspension unless cosmetic. The OP was discussing fuel tank fixings and supports though and I would sincerely hope they are not subject to any extreme loads.
britmog #745409 21/06/22 07:52 PM
One of my neighbours is a retired RM RSM.
Could it be?
Bud
4/4 - Stanley
budster
Bud
4/4 "Stanley"
Budster #745429 21/06/22 10:37 PM
Could it be?
Bud
4/4 - Stanley
budster
My Troop Sergeant is at the Final RV so it won't be him, but most RSMs were Nut Splitters too redcard rofl
Bruce
2013 M3W (Olga)
IcePack #745431 21/06/22 10:54 PM
Snap On
IcePack #745472 22/06/22 10:58 AM
tight undercrackers work!!!!!
