4 members (SwissMogFan, moggywills, RedThree, JMcL), 201 guests, and 56 robots.
+8Rich 83
Luddite 50
Posts837,946
GLLOQ #749887 30/07/22 11:47 AM
GLLOQ Offline OP
It left, I only took the opportunity to replace the rear electrical outlets and the rear cover wiring, the result of more than fifteen days of work.
GLLOQ #749889 30/07/22 12:01 PM
GLLOQ Offline OP
for the moment I connected the two tanks with a rubber hose because the aluminum pipe rubs in several places, I plan to connect the two tanks with a 15 ID 21OD hose with exterior metal braid.
GLLOQ #750203 01/08/22 04:04 PM
That is excellent work! The plywood should hold up better than the ash.
GLLOQ #750263 01/08/22 08:41 PM
These people won't be pleased with the use of plywood. They supply Morgan with top quality Ash wood grown in Lincolnshire, England. I can only assume that it's treatment was a bit 'iffy" or you have given it a fairly demanding life? My 2013 cars wood frame still looks like new after 35,000 miles. Admittedly it hasn't been used in the depths of Winter and has been kept fairly clean.
