Posts837,956
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
for the moment I connected the two tanks with a rubber hose because the aluminum pipe rubs in several places, I plan to connect the two tanks with a 15 ID 21OD hose with exterior metal braid.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
That is excellent work! The plywood should hold up better than the ash.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
These people won't be pleased with the use of plywood. They supply Morgan with top quality Ash wood grown in Lincolnshire, England. I can only assume that it's treatment was a bit 'iffy" or you have given it a fairly demanding life? My 2013 cars wood frame still looks like new after 35,000 miles. Admittedly it hasn't been used in the depths of Winter and has been kept fairly clean. ![[Linked Image]](https://www.tm-img.com/images/2022/08/01/DSC07374.jpg)
