6 members (Alan Patterson, nick w, Barry M, Pittsartist, Anonymouse, Morganmike), 298 guests, and 33 robots.
+8Rich 96
John V6 51
Topics49,900
Posts838,035
Page 3 of 4 1 2 3 4
John V6 #749779 29/07/22 10:54 AM
Can someone explain how a swirl pot works?
What are the effects on the radiator?
Do the Z4s have this type of equipment?
gaston #749780 29/07/22 11:02 AM
Gaston - Richard explains a little on this post - it was all new to me also..Swirl pot..
Good luck getting your car rectified.
gaston #749788 29/07/22 11:56 AM
Scroll down this page for general description of swirl pot/tank function.
John V6 #749790 29/07/22 12:32 PM
My own thoughts which are just that, is that the unique fit, coolant plumbing and components of same on BMW's well proven B48 variant collectively cause the issue. Maybe under sudden load, steam is allowed to form probably in the integral to head exhaust manifold. When the thermostat in the radiator return fully opens, such steam pockets enter top of rad and cause mechanical shock from the thermal shock due to sudden cooling.
Cars driven on the track where stat is open most of the time or at the other extreme when gently driven will likely never experience this issue, explaining why not all rads fail and wasn't noticed in original testing.
Certainly mechanical shock in plumbing is well demonstrated at home when a tap is turned off suddenly and a poorly supported copper pipe rattles or bangs, which can turn to leaks at any adjacent joint over time.
John V6 #749798 29/07/22 02:26 PM
John V6 Offline OP
I too think it is thermal shock / pipe hammer. The earlier fix of lowering both the coolant header tank level and the pressure the cap blows at means there is more air that compresses easily to dampen any hammer & in the worst case vent gas.
In industry pneumatic dampers are quite common to stop pipe hammer caused by say a valve closure on a circuit.
John V6 #749799 29/07/22 02:28 PM
I dont buy thermal shock cracking welds
My thoughts are that the top 6" of the radiator are completely unsupported- and MMC's fix to date has been to increasingly stiffen the mountings hence the welds cracking...
Also the Header tank is too small to accomodate for coolant expansion. I bet that during testing the cars kept spitting out coolant- hence they were delivered with a 25 odd lb radiator cap to try and keep the coolant in....
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
John V6 #749800 29/07/22 02:30 PM
Thank you for your feedback.
SimonH #749801 29/07/22 02:44 PM
John V6 Offline OP
My thoughts are that the top 6" of the radiator are completely unsupported- and MMC's fix to date has been to increasingly stiffen the mountings. Also the Header tank is to small to accomodate for coolant expansion. I bet that during testing the cars kept spitting out coolant- hence they were delivered with a 25 odd lb radiator cap to try and keep the coolant in....
Simon I agree the tanks are very small indeed. Lets hope they find the solution
John V6 #749802 29/07/22 02:54 PM
Perhaps they should pay me consultancy.....
Simon @ Sifab.co.uk
John V6 #749803 29/07/22 03:30 PM
I can perhaps advance them the money to be definitely quiet. innocent
Page 3 of 4 1 2 3 4
