1 members (Alan Patterson),
210
Posts837,998
Posts: 58 |
Have a '95 Plus 8. The seat belt retractors do not do a very good job of rewinding the belt after use. Is there a spring adjustment of any type in the unit? Or, is it s lubrication thing?
TIA Tom
Posts: 37,479 Likes: 988
Posts: 37,479 Likes: 988 |
Hi Tom, I have never done it myself but it seems they are adjustable here.
Posts: 3,826 Likes: 69
Posts: 3,826 Likes: 69 |
My 85 belts were bad. I pulled them fully out and squirted a very small amount of wd40 into the bearings. They've been excellent ever since. Nick
Posts: 502 |
Mine are awful. If the lock engages it never seems to want to release for ages.
2004 Series 1 Roadster
Posts: 8,696 Likes: 498
Posts: 8,696 Likes: 498 |
I think John V6 found a safe spray lube that can be used ?
Posts: 6,675 Likes: 441
Posts: 6,675 Likes: 441 |
I think John V6 found a safe spray lube that can be used ? TUNAP 104
Posts: 1,987 Likes: 104
Posts: 1,987 Likes: 104 |
Worked for me. Read the instructions as over-use can leave blobs (dodn't ask how I know, fortunately on the tin-top).
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 1,309 Likes: 5
Posts: 1,309 Likes: 5 |
I find the folded hood interacts with the webbing causing them to stick. Its something I need to address as sometimes when I re-adjust my position while driving, I'm left with a baggy bit of webbing flopping around till it decides to tighten up a bit !
Bonesie Current stead -'The Captain' Black +4 'Life is like a garden, dig it' *Joe Dirt
Posts: 5,468 Likes: 172
Posts: 5,468 Likes: 172 |
How do you fold your hood ?
This is not a problem I have ever encountered. I have had badly placed luggage cause an issue - I always check the belts now when I am loading up for a trip.
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
I when I re-adjust my position while driving, I'm left with a baggy bit of webbing flopping around till it decides to tighten up a bit ! I believe you can buy pills for that
