6 members (Jon G4LJW, James B W, JohnHarris, Rog G, DazMog, Sukram), 220 guests, and 39 robots.
+8Rich 94
John V6 50
Posts837,997
rockabilly john
#749890 30/07/22 12:07 PM
Have a '95 Plus 8. The seat belt retractors do not do a very good job of rewinding the belt after use.
Is there a spring adjustment of any type in the unit?
Or, is it s lubrication thing?
TIA
Tom
Hi Tom,
I have never done it myself but it seems they are adjustable here.
My 85 belts were bad. I pulled them fully out and squirted a very small amount of wd40 into the bearings. They've been excellent ever since.
Nick
Mine are awful. If the lock engages it never seems to want to release for ages.
2004 Series 1 Roadster
I think John V6 found a safe spray lube that can be used ?
TBM Offline
TUNAP 104
Worked for me. Read the instructions as over-use can leave blobs (dodn't ask how I know, fortunately on the tin-top).
I find the folded hood interacts with the webbing causing them to stick.
Its something I need to address as sometimes when I re-adjust my position while driving, I'm left with a baggy bit of webbing flopping around till it decides to tighten up a bit !
Bonesie
How do you fold your hood ?
This is not a problem I have ever encountered. I have had badly placed luggage cause an issue - I always check the belts now when I am loading up for a trip.
Costock, UK
Disco 5
Black Rat
Black Rat
Originally Posted by Bonesie
I when I re-adjust my position while driving, I'm left with a baggy bit of webbing flopping around till it decides to tighten up a bit !
I believe you can buy pills for that hide
Keith
2013 narrow bodied + 4 Ruby.
