3 members (Carbuilder, JoeSpeetjens, uvk33n), 297 guests, and 33 robots.
+8Rich 96
Luddite 54
Topics49,904
Posts838,083
#750637 03/08/22 09:59 PM
C2RM Offline OP
6 days into ownership and still finding my way around the car - 70th Anniversary 4/4
The car had/has a satnav mounted under the dash which doesn’t seem to work. It powers up but the gps isn’t updating my location
Anyway, I want to replace it and there’s a panel under the dash the the current fitting it attached to - is the panel normal fit?
Also, what is the small button for - any ideas?
4/4 70th Anniversary
If you are mounting the satnav under that plate you are obstructing the signals from the satellites..... dont forget that those signals have travelled 20,000 kms to get to you and any obstruction will weaken/ block the signal if that close to the antenna..
Keith
Hi C2RM,
The plate is standard but sorry, I can't help with the aftermarket black button.
It can get a bit tight down there with the handbrake, radio and heater vents plus I could never get a good viewing angle.
So, best of luck.
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Yes poor location of Satnav antenna which is probably integral to unit, and definately not a standard fit. This would likely have been explained in the fitting instruction's. Although impractical, its been proven that a GPS receiver will work on top of the transmission tunnel slightly forward of gear lever. It needs to see the sky unimpeded although the canvas hood wouldn't affect too much, ditto for glass.
Think the button is for “Traffic master”. The system monitors traffic flows to warn you of hold ups ahead. I only got this info by googling and have no experience of it myself.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
I have a gps unit for my cruise control it sits under the leather gearbox cover just as Richard describes & works well
John, you have cruise control on your roadster? I am now intrigued, as I have been looking at aftermarket stuff however seems I would need a few gadgets notably a Mondeo steering wheel. What have you got fitted?
ABBO
Morgan 2005 Roadster
Morgan 1986 4/4 4str Prev
Morgan 1953 +4 DHC Prev
Flippin Pongo 3008 Hybrid
Here you go cruise control
I was sure the "TM" button was to instantly upload to Talk Morgan!
No?
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
Wow, there's a blast from the past, I'd forgotten all about Traffic Master. It used to come as standard on Vauxhalls in the 1990s. The system was apparently retired in June 2012, according to Honest John, presumably superseded by newer technologies. I'd offer that button to a transport museum.
2011 Morgan 4/4
1932 Austin 7 Chummy
