3 members (Zach, DCH, sezznowt), 227 guests, and 29 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,147
Page 2 of 4 1 2 3 4
Budster #75069 29/11/11 12:06 PM
Stock Morgan answer "They do that, Sir"
Regards
Alan
AP08 MOG
n1ck #75074 29/11/11 12:58 PM
I picked up my car new from the factory in a January planned an epic journey north through the Lake District and beyond. Within minutes from Malvern never saw a clear dial until 500 miles later in the garage. Presumed it was a fault, but no they all do this to varying degrees, my latest car lasts a bit longer before misting up but gets there in the end. I think the mist looks better on white faced dials rather than black. There were a few solutions suggested, one was the hairdryer to heat up the dial and purge out the damp air, another was accessing the dials behind the dashboard to squirt in canned air to replace the moist stuff. I was out in my car yesterday and in about 10 deg the mist was back after 5 miles.
I think we've all asked this question at some time...
nputtick #75087 29/11/11 02:17 PM
I like Steve Villatoro's comment, albeit he made it about the M3W.
"It is all part of the charm that can never be replicated by perfection"
cheers
Bud
4/4 "Stanley"
Budster #75089 29/11/11 02:33 PM
cheers
laugh2
A11OGE #75110 29/11/11 04:31 PM
U
TM Photographer of 2008
U
Put your lights on - that will get rid of it.
Ken
uvk33n #75127 29/11/11 07:21 PM
A little warmth is the answer. That is why the instrument lights alleviate the condition. An easy solution is to add heat. See below
http://www.oemheaters.com/c-983-freezestop-12v-heat-cable.aspx?gclid=CK-QscjY3KwCFeddTAodOn21-Q
Something of this nature wired to the run position of the ignition
'65 +4 four seater
n1ck #75187 30/11/11 07:15 AM
Posting Desperado
Posting Desperado
I had the same problem sent them to Speedograph Lichfield they stripped them sprayed the inner case brilliant white ( more light ) then removed the plastic lens that sits in front of the bulb it has worked I can dig out the bill if you wish .
JTL. doh
n1ck #75217 30/11/11 09:04 AM
Exactly the same for me,two months old car,running with lights on and 4 hours in a hot Aussie sun and still fogged up. Pink
Do you mean the fog is pink? I have heard of the "red mist" but a pink fog must be the girlie version rofl
Seriously if the mist is pink it can not be normal condensation of humid air inside the instrument. Perhaps it is caused by some lubricating oil or other fluid escaping inside the instrument. That would definitely be a fault.
Page 2 of 4 1 2 3 4
