Topics49,911
Posts838,146
Posts: 2,125 Likes: 37
Posts: 2,125 Likes: 37 |
Stock Morgan answer "They do that, Sir"
Regards Alan AP08 MOG 2016 Plus 4 GDi - Mazda Soul Red Metallic
Posts: 1,597 |
I picked up my car new from the factory in a January planned an epic journey north through the Lake District and beyond. Within minutes from Malvern never saw a clear dial until 500 miles later in the garage. Presumed it was a fault, but no they all do this to varying degrees, my latest car lasts a bit longer before misting up but gets there in the end. I think the mist looks better on white faced dials rather than black. There were a few solutions suggested, one was the hairdryer to heat up the dial and purge out the damp air, another was accessing the dials behind the dashboard to squirt in canned air to replace the moist stuff. I was out in my car yesterday and in about 10 deg the mist was back after 5 miles.
Posts: 1,502 |
I think we've all asked this question at some time...
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
I like Steve Villatoro's comment, albeit he made it about the M3W. "It is all part of the charm that can never be replicated by perfection"
Bud 4/4 "Stanley"
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
Posts: 849 Likes: 2
TM Photographer of 2008 Talk Morgan Regular
Posts: 849 Likes: 2 |
Put your lights on - that will get rid of it.
Ken
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
I had the same problem sent them to Speedograph Lichfield they stripped them sprayed the inner case brilliant white ( more light ) then removed the plastic lens that sits in front of the bulb it has worked I can dig out the bill if you wish . JTL.
Posts: 152 |
Exactly the same for me,two months old car,running with lights on and 4 hours in a hot Aussie sun and still fogged up. Pink
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
Exactly the same for me,two months old car,running with lights on and 4 hours in a hot Aussie sun and still fogged up. Pink Do you mean the fog is pink? I have heard of the "red mist" but a pink fog must be the girlie version  Seriously if the mist is pink it can not be normal condensation of humid air inside the instrument. Perhaps it is caused by some lubricating oil or other fluid escaping inside the instrument. That would definitely be a fault.
