7 members (Bilymog, JohnHarris, sprinty, verysideways, aerotaff, TalkMorgan, Bishmog), 201 guests, and 44 robots.
+8Rich 90
Luddite 50
Posts837,962
#751663 11/08/22 03:31 PM
paulmog Offline OP
Does anyone know the size of the torx button head screws that secure the wings to the body?
What year car? My guess would be M5/T25 (8mm spanner on the nut) as that's the closest metric size to the 2BA that they always used to use before they converted to metric fasteners.
paulmog Offline OP
It's a 2017. I thought either M4 or M5 but to the eye there's not much difference. They are 20mm in length.
Well if a T20 bit fits the head it's M4, but if it's T25 then it'll be M5.
paulmog Offline OP
Having checked it's the T15 bit that fits so I guess it must be a M3 then??
Hmm, that's strange. Standard torx size for M3 is T10, T15 is for M3.5 so I suspect you have a non-standard M4 or M5, M3 or 3.5 seems far too small for a wing bolt.
Best way to check is to put a spanner on the nut underneath, this will tell you. if you need an 8mm spanner it's M5, 7mm for M4, 6mm for M3.5
paulmog Offline OP
They screw into rivnuts rather than a conventional nut.
Blimey, there’s modern for you. Easy enough to whip one out and measure it then.
X
X
Mudguards at bicycles are usual fixed with M5 screws. M4 for a MORGAN would be a little bit to small.
A few years ago I customized a friends Harley. I fixed the carrier for the rearlight and the numberplate with three M5 screws and selfsecuring nuts.
The Harley vibrations undo the screws in a VERY short time.
So I think more on the M5 than M4.
Greets René
2018 plus4 (sports green)
Yes M5 x 12mm with nylon washer into captive nuts on my 2018 car. Mine were factory new button socket head when I changed them like for like with stainless.
In any case you are more likely to have a suitable 4mm Allen key around than equivalent Torx tool.
