Topics49,915
Posts838,211
Posts: 1,415 |
I would agree Richard the tooling for that would be I guess £100k up and you would need a good blow moulder to make it. The Morgan script is probably a mould insert. I'm guessing Ford also put different branding on it where the Engine is used e.g. Mercury , Lincon & Mazda. Its very different to the Mustang and Transit intake- its much shallower to fit under the Morgan bonnet...
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 27,852 Likes: 767
Posts: 27,852 Likes: 767 |
I guess we will never know Simon but that isn't a cheap moulding. Look at the low cost filter housing from fibre glass on the S1 Roadster. My guess is it is used by Ford on one of the many uses of the engine.
Moulds like this are also often made in pieces to make machining easier. I guess it is possible MMC only need a small bit rejigging.
Posts: 8,708 Likes: 501
Posts: 8,708 Likes: 501 |
The 3.7's come in crated and already assembled from Power Torque Eng Ltd, but don't waste your time asking them as they are totally un-responsive to tech queries ![[Linked Image]](https://www.tm-img.com/images/2020/09/06/Engine-April-2018-2.md.jpg)
Posts: 37,490 Likes: 994
Posts: 37,490 Likes: 994 |
They have learnt well from the customer
Posts: 8,704 Likes: 416
Posts: 8,704 Likes: 416 |
Power Torque still offer this Cyclone variant. ![[Linked Image]](https://i.imgur.com/DKyHmov.jpg) Looks quite compact. Variants 310-660 hp
660 bhp! Can the chassis take it captain?
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
660 bhp! Can the chassis take it captain? A new meaning of crate engine.
Moulds like this are also often made in pieces to make machining easier.I guess it is possible MMC only need a small bit rejigging. Or, in the case of the airbox inlet, rough modification with a hacksaw!
Posts: 41 |
The top section has the Morgan emblem moulded into it, so isn’t it likely this would be a customised top mould ?
