4 members (Eastertown, Tony Quinn, Hamwich, James B W), 386 guests, and 54 robots.
+8Rich 62
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,766
Newboy #756221 22/09/22 06:54 AM
Originally Posted by Newboy
Thanks all for your comments and suggestions. Have had battery and charging rate checked
at local ATS garage, both good. Battery is new “Red Gel” which I understand to be
good quality. Having charged up overnight I will see what happens in a few days but also
considering an isolating switch, but still find it hard to believe it will normally drain so quickly
Appreciate the support.
My car is 2002 and holds charge for weeks, you have a current drain somewhere. As has been suggested put a multimeter in line between battery and earth and measure current. If you do have a current draw try removing fuses. If that doesn’t work remove them all then replace one at a time. If one is affected there’s your problem.
Simon
2002 4/4
2021 Audi A1 sport
Guten #756689 27/09/22 08:38 PM
I think the ECU is also a current drain as it often has to be kept "alive" when the ignition is turned off.
1994 +8, BMW Calypso Red.
How do you open the boot?
