Topics49,921
Posts838,285
Posts: 116 Likes: 2
Posts: 116 Likes: 2 |
Grumpy, I'm not sure whether this will help or not, but I just installed the overflow lines in my car. I used ¼" fuel line rated for fuel injection systems. I'm sure regular fuel line would have been fine, as there is no pressure, but it's all my local parts store had. After three weeks of no Moggie, I didn't have the patience to start a parts search. I rant the tubing down the inside of the inner valance. On my car, there is a small harness going to the front lights, as well as the hard pipe for the one-shot. I followed the one-shot pipe to the removable section of firewall near the cernterline. I added an Adell clamp to turn the hoses downward. The Adell clamp is mounted with one of the center section fasteners. Everything else was buttoned up with nylon wire ties. It's a similar path to the overflow piping on my mother's '64 drophead. It's a difficult spot to get a decent photo. Hopefully this one will help. Naturally, I needed to go for a test drive...Yippee! ![[Linked Image]](https://tm-img.com/images/2022/10/12/IMG_3256.jpg)
Posts: 5,473 Likes: 476
Posts: 5,473 Likes: 476 |
I suspect with all that effort, you may have just guaranteed never to suffer a sticking float needle ever again GP...
Posts: 812 Likes: 62
Posts: 812 Likes: 62 |
I suspect with all that effort, you may have just guaranteed never to suffer a sticking float needle ever again GP...  +1 You did allow enough room for flexing as the motor shifts during acceleration, correct? I know I don't need to ask....but I had to!
Posts: 116 Likes: 2
Luddite: I hope you are right! Pauly: What acceleration?
I saw you on the track at Luray. You have some.
Posts: 116 Likes: 2
Pauly, Maybe a little more on the way... ![[Linked Image]](https://tm-img.com/images/2022/10/14/IMG_3251.md.jpg)
Posts: 5,609 Likes: 618
Posts: 5,609 Likes: 618 |
Something I've been meaning to do for a while ... aluminium fire extinguisher fitted .... tucks neatly under the front of the passenger seat with the holder screwed into the wooden seat raisers ... wouldn't know it was there .... having had old cars over the years (and had a distressing incident helping another classic car owner trying to put out an electrical fire on the shoulder of the M62 with no extinguisher or the bolt croppers it would have taken to cut the shorted starter feed that kept re-igniting itself) I always fit a big red battery-earth cutout switch right there on the dash (which can be pocketed on parking as an extra security device) and an extinguisher. ![[Linked Image]](https://www.tm-img.com/images/2022/10/16/20221016_165341.jpg) K
Posts: 27,856 Likes: 767
Posts: 27,856 Likes: 767 |
What in the blastic box that sits on the tunnel?
It covers the hole to accommodate the shift mechanism of the type 9 five speed that was fitted by a previous owner ... the tunbel is the pld four speed one 'modified' (with a can-opener by the look of it! 🙂) ... just covers and tidies everything up.
