1 members (DJC),
336
Topics49,904
Posts838,088
Posts: 502 |
Having tried searching the forum for rattles, the amount that come back are many as you'd imagine so have started a new one.
Was out today with the sidescreens off which I don't normally do. I have a rattle/tinkling noise which appears to be coming from under the car. It sounds like it would be the bonnet stay rattling in its holder, but that's secure. It's not rattling on idle and happens on smooth roads, but worse on rougher roads. Any idea before I get it up on axle stands, what it could be?
2004 Series 1 Roadster
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
Do you have an aerial? The sections/tubes rattle in mine.
Roger 2011 Plus 4
Posts: 809 Likes: 59
Posts: 809 Likes: 59 |
I feel good about rattles. It means the part hasn't fallen off yet.
Posts: 502 |
Do you have an aerial? The sections/tubes rattle in mine. I do, and it was retracted, will put that on the list to check. I guess if it was fully extended then less likely to rattle.
Posts: 502 |
I feel good about rattles. It means the part hasn't fallen off yet. 😂 The important bit being YET.
Do you have an aerial? The sections/tubes rattle in mine. I do, and it was retracted, will put that on the list to check. I guess if it was fully extended then less likely to rattle. I’ve never extended mine. It’s on my list to remove. Who would ever spec a wireless on a trad…..
Roger 2011 Plus 4
Posts: 502 |
My aerial does in deed rattle, and another culprit could be the luggage rack part that you remove to stow the sidescreens. Think another test drive is in order. 😊
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Could it be exhaust related ?
Posts: 8,697 Likes: 416
Posts: 8,697 Likes: 416 |
This was cause of my recent rattle  ![[Linked Image]](https://i.imgur.com/SBDU9vX.jpg)
Ah yes that reminded me... If you have the RS front with these Bilsteins take a look here.![[Linked Image]](https://dl.dropboxusercontent.com/s/3brzue5z5zdofwo/tinkle.jpg)
Roger 2011 Plus 4
