9 members (JohnHarris, IcePack, lez, dakri, JoeSpeetjens, MartinB60, HJP, Plus Four Guy, TBM),
295
37
Posts837,974
Posts: 58 |
1995 Plus 8 Is there a tool to grab the round knob on the side brackets of a folding windscreen? I would like to fold it down for winter storage, but the round knobs aren't moving. I see holes drilled in the outer rim. I'm assuming for some kind of tool. I wrapped them in rubber so as not to scratch them up, but they're not budging.
Also: does the screw in the center have anything to do with it, or does it just hold the knob to the shaft?
Thanks Tom
Posts: 6,675 Likes: 441
Posts: 6,675 Likes: 441 |
Ideally you need the 'Morgan Tommy Bar' - available at all good Morgan suppliers, but any lever/bar inserted in the holes would suffice - screwdriver, allen key etc....
The centre screw holds the knobs on as you suggest.
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
If this is the same as the side screen knob, Cain at Wolf Performance markets the “Claw” in his tools section for £23, especially designed for the job.
Posts: 5,594 Likes: 612
Posts: 5,594 Likes: 612 |
Mine had a tommy bar as it's keyring so it's always to hand .... an old scrap screwdriver with the right shaft diameter and the end cut off will do to put into the hole for leverage ... also the blunt end of a drill of the right diameter (but wear sturdy gloves to protect from cuts... or breakages if you're really strong)
Sometimes gently flexing the screen as you turn will loosen things up ... a thin smear of grease on the shoulder that locates in the screen bracket will help for next time.
Posts: 27,835 Likes: 758
Posts: 27,835 Likes: 758 |
Same Tommy bar as the side screens. Sounds like some penetrating oil overnight might help.
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
My mechanism has the Tommy bar holes, too. Amazing how tight these knurled knobs can become.
Perhaps wear a thick rubber glove (or two) and give it a twist (works with stuck fishing rod joints). If not then yes, Tommy bar substitute + maybe the penetrating oil.
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Then once lose add grease or copperslip to the threads
