6 members (Paul F, Morganmike, MOG42, High Hamster, nick w, Haggispeed), 158 guests, and 143 robots.
+8Rich 101
John V6 66
2001 +8 Temperature gauge
by AlanB - 16/09/26 07:39 PM
Longest owner?
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,921
Posts838,289
Smed., Spanner Juggler
#763740 09/12/22 04:47 PM
PaulyG Offline OP
Is there a difference between carbon core and graphite core? I've searched around and cannot find any info. I see listings for one or the other, but not both.
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
PaulyG #763751 09/12/22 06:14 PM
Not sure .... but graphite is a form of carbon so maybe they're the same thing
PaulyG #763756 09/12/22 07:35 PM
I was thinking the same as K - either wire or carbon/graphite I think.
PaulyG #763763 09/12/22 09:10 PM
Yes, just two types: copper wire, often tinned to minimise corrosion; or graphite, sometimes referred to as carbon. Carbon is a bit of a generalisation as it comes in several forms, e.g. diamond is a form of carbon. But graphite is the only form of carbon that will conduct electricity, so that is a more fitting name for the plug leads. It is also good at withstanding heat..
The reason for graphite over copper is to introduce some electrical resistance to quench some of the spark energy, in order to reduce radio frequency interference. That can have a marked effect on electrical equipment in the car and also on domestic tv and radio reception. If you cut one open, the core looks like a slippery black, stringy material. It is in fact fibre glass impregnated with graphite powder.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
PaulyG #763799 10/12/22 12:29 PM
PaulyG Offline OP
Thanks for the info. You learn something new every day.
73 4/4 "Henry A"
60 MGA
PaulyG #763877 11/12/22 10:43 AM
CBY Offline
Don't pull on the carbon wire, this is not copper and it breaks inside very easily. Pull only by the plug cap.
Regards
2005 PLUS 4
