5 members (John V6, Chris Cosher, jbk, RichardV6, bmgermany), 311 guests, and 39 robots.
+8Rich 96
John V6 51
Topics49,899
Posts838,024
#764484 16/12/22 04:47 PM
Grumpy2 Offline OP
Did they really make a 4/4 with the Ford 1.8 engine circa 2011. I’d have thought it would be a 1.6. Too early for Mazda box too I assume.
Spotted an in an ad, may be a typo?
Grumpy2 #764489 16/12/22 05:17 PM
The 1.8 Duratec was used up to early 2008 and changed to the 1.6 Sigma for the 4/4 Sport. Not sure about the Mazda box, thought it was around 2010/11.
Pete
Grumpy2 #764494 16/12/22 05:27 PM
In 2011, only the 1.6 litre Sigma was installed in the normal 4/4. But in 2011 there was also the 75s anniversary 4/4 with the 2 litre Duratec engine. I'm not sure if this model already had a Mazda gearbox? The 2012 Plus 4 Super Sport had a Mazda gearbox, perhaps the earliest Mog with the Mazda box? DaveW could answer this Q.
Grumpy2 #764498 16/12/22 05:36 PM
I believe the factory started installing the Mazda box in 2012
Craig Jezz
Grumpy2 #764546 17/12/22 09:22 AM
JJR Offline
My 2011 Plus 4 had a Mazda box. Best gearbox I have ever had.
John R Marchant
Plus Four JT10MOG "Florence"
Grumpy2 #764550 17/12/22 10:49 AM
My Nov 2011 4/4 has the sigma 1.6 married to the Ford box.
Grumpy2 #764554 17/12/22 11:32 AM
My Feb 2011 definitely has the Mazda box.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Grumpy2 #764559 17/12/22 11:52 AM
Grumpy2 Offline OP
is there and easy way to distinguish the Mazda box from the ford. having owned (and still do own) several MX5s I agree the gearbox is usually delightful.
Grumpy2 #764573 17/12/22 01:02 PM
On mine, if I open the bonnet on the driver’s side and with a torch, peer down and back into the gearbox tunnel, to where the gear box is bolted to the back of the bell housing. There on the gear box casting, at an angle of about 45 degrees to the horizontal is a stick on label showing N7S together with a serial number and bar code. N7S is the Mazda designation.
Doug
1958 Triton 650
Grumpy2 #764575 17/12/22 01:14 PM
Grumpy2 Offline OP
Brill, great info. Thanks
