7 members (John Winn, TalkMorgan, GrumpyPa, Rog G, RichardV6, Laurens, Craig Jezz),
341
38
Topics49,918
Posts838,244
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
Yesterday, actually, I installed the Brake Reaction Stays... ![[Linked Image]](https://tm-img.com/images/2022/10/22/IMG_5370.jpg) Good call on fitting BRB's as many others have said. I note your upper shock mount bracket has the bend facing upwards though  unless a second opposite bend has been added. You can see above the shock fits and works at an angle to kingpin, so the bend is to accomodate as per my recently fitted bracket below with bend downwards. ![[Linked Image]](https://i.imgur.com/sxFN9ah.jpg) It's whatever brackets that were on the car when we got it last June. It has the SSL suspension, so would that make a difference? The shocks are at an angle to the kingpins, but it doesn't show as much in this photo...
Posts: 8,706 Likes: 416
Posts: 8,706 Likes: 416 |
You can see above the shock fits and works at an angle to It's whatever brackets that were on the car when we got it last June. It has the SSL suspension, so would that make a difference? The shocks are at an angle to the kingpins, but it doesn't show as much in this photo... No the SSL RS kit would not affect the shock mount. It's possible earlier brackets were of a differing design but only one version is listed by Mogparts in the UK. It's difficult to see in your photo but if there are two bends in bracket (one up and slightly greater one down) then that would correct the difference in angles of kingpin and damper. Apologies for raising the issue but it just looked wrong having the visible bend upwards when it clearly should be fitted downwards to match damper angle. Whilst in this area worth checking the static pre-load on lower rebound spring. The two locking collars are shown in the very highest position but are there to allow adjustment such that stub axle just touches spring without any extra play. This is the optimum setting and does need to be checked a few thousand miles after kit is fitted to correct for main spring settling. A pair of C spanners allow adjustment and are provided with SSL kit - hopefully you have them in your toolkit.
Posts: 2,096 Likes: 75
Posts: 2,096 Likes: 75 |
Good advice from Richard regarding setting of static ride height. Depending on the age of this car, (unknown, but worth adding to your postings in future), it may not be far out. SSL recommendation for 4/4 Sport and Kent engine models recommend a starting point. of zero exposed thread for the car on the low ground clearance setting or 20 mm if on the higher clearance. But as Richard says, individual adjustment is the way to go following SSL recommended method.
By the way, referring to the earlier posting, as most of the braking action comes from the front, personally, I would not fit “performance” linings to the rear, unless of course it is destined for race or track use. For road use, it is a waste of money and it could even make the braking slightly worse.
Posts: 811 Likes: 59
Posts: 811 Likes: 59 |
The proper way to work on your Morgan! https://youtu.be/4tB9Dfr4Prk
Posts: 27,853 Likes: 767
Posts: 27,853 Likes: 767 |
Hopefully I know where the all go.
It the bits left over that usually worry me
Posts: 6,680 Likes: 441
Posts: 6,680 Likes: 441 |
Had an intermittent fault on my rear reverse/fog lights (I have LED combined red/white bulbs in a stop/tail light fitting). Stripped down the light and a combination of poor manufacturing tolerances on the new light fitting and softer aluminium body on the bulb means that it keeps wagglng loose.
Am going to solder leads to the bottom of the bulbs and then wedge them in the fittings..... Leads soldered on, and bulbs packed with copper tape and wedged in the holes! All working as they should. Annoyingly, there does seem to be a UK shortage of 4.7mm bullet crimp connectors, Can get my usual type for love nor money, and don't like the brass solder/crimp type.... ![[Linked Image]](https://www.tm-img.com/images/2023/01/08/bullet.jpeg)
Posts: 1,062 Likes: 156
Posts: 1,062 Likes: 156 |
This is a big one this boys, so sit down. Making use of the little thin tube that comes on a Twinspray Action Can, can I sprayed liberal quantities of AC-90 lubricant down the gaps around the leather covered steering cowl. To make sure I properly drowned that damn mouse who's lived in there since Monty came into my life last summer I absolutely flooded the area with AC-90, and then vigarouisly worked the wheel from lock to lock a number of times. The result???? The anoying squeek from the steering column is finally gone
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
Result - now you need to find all the other mice.  This is a big one this boys, so sit down. Making use of the little thin tube that comes on a Twinspray Action Can, can I sprayed liberal quantities of AC-90 lubricant down the gaps around the leather covered steering cowl. To make sure I properly drowned that damn mouse who's lived in there since Monty came into my life last summer I absolutely flooded the area with AC-90, and then vigarouisly worked the wheel from lock to lock a number of times. The result???? The anoying squeek from the steering column is finally gone
