2 members (sewin, Tony Quinn),
274
51
Posts837,962
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Cain @ Wolf performance has a 2011 4/4 sport it didn't have a LSD. My 2013 +4 does have one.
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Thanks Richard, I had already read that thread but there's no definitive answer as to if LSD became a standard fitting and if so when. Specifically on the 4/4 Sport but perhaps across the range.
I have never seen LSD advertised as a standard fitment in any Morgan specification sheets for new cars, nor is LSD on the options list for 2012 onward 4/4's I have been told that LSD became standard around 2014, but if so that doesn't explain my 2012 car having it.
My 2016 4/4 Sport is None LSD
Craig Jezz
Posts: 902 |
Thanks for the replies so far.
The LSD on my car isnt noisy at all.
The other thing I was told is that LSD became standard at around the same time as the camber adjustment was made standard on the front suspension.
My September 2012 car also has these camber adjustment plates.
Rob
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
My 2009 4/4 Sport has an open dif and I have been considering an LSD upgrade, but have been advised they are all noisy by comparison with the open dif. If you have an LSD, is it noisy? If it isn't, I want one! When I got Billy Bellinger to rebuild my axle I asked him to put a Quaife ATB diff in. It's definitely a lot quieter than the old open diff, but then that was knackered, which is why I had it rebuilt in the first place. If you fancy a LSD, I thoroughly recommend you consider an ATB instead. https://www.quaife.co.uk/quaife-products/atb-limited-slip-differential/
Posts: 8,692 Likes: 498
Posts: 8,692 Likes: 498 |
Good idea the check which diff you actually have (easy test as per Dave W's post) because you should be using different oils and LSD additives...worth reminding your dealer if they do your servicing too
Posts: 81 Likes: 1
Posts: 81 Likes: 1 |
Kevin Davies
Posts: 902 |
Good idea the check which diff you actually have (easy test as per Dave W's post) because you should be using different oils and LSD additives...worth reminding your dealer if they do your servicing too , Agree Jon, and you dont want your brakes tested on a rolling road for MOT if you have a LSD either or so ive been told
Rob
Posts: 902 |
Is it possible the low ratio 4.11 axle was used on the limited production performance models and this had LSD?
Hi Richard I believe Kev posting above (Alpha1) has a 4.11 axle and he doesn't have a LSD
Rob
Posts: 267 Likes: 2
Posts: 267 Likes: 2 |
That Quaif dif is very sexy....
That Quaif dif is very sexy.... and it works extremely well too. Very controllable.
