7 members (Craig Jezz, MOG42, Lordofthewings, Lance, IcePack, MJF, JMcL),
385
50
Topics49,918
Posts838,244
Posts: 8,712 Likes: 501
Posts: 8,712 Likes: 501 |
He's hibernating...bit of warm weather and a run out in the Mog and Mr Squeak will return, I've been chasing one down for over four years
Posts: 27,853 Likes: 767
Posts: 27,853 Likes: 767 |
As it is wet & windy I cleaned & conditioned the leather. I just love that gliptone smell. This pm I'll treat Belle to gonig over with utlimate detailer. A good way to avoid spending the afternoon listening to  &  Snr .
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
Put her into her winter storage container. Projects start tomorrow. Next year she will have her own dedicated garage. ![[Linked Image]](https://www.tm-img.com/images/2023/01/18/IMG_5531.jpeg)
Posts: 116 Likes: 2
Posts: 116 Likes: 2 |
After a couple of months of futzing around with replacing the fuel lines, adding an electric pump and filter/regulator, and sending my header out for reconditioning and ceramic coating, I finally heard my car running with Weber carbs today. I had a couple of missteps, but sorted them out after a bit of head scratching. The next step is to start fussing with the tuning. I'm hoping that the AFR gauge helps shorten that process. ![[Linked Image]](https://tm-img.com/images/2023/01/23/IMG_3490.jpeg)
After a couple of months of futzing around with replacing the fuel lines, adding an electric pump and filter/regulator, and sending my header out for reconditioning and ceramic coating, I finally heard my car running with Weber carbs today. I had a couple of missteps, but sorted them out after a bit of head scratching. The next step is to start fussing with the tuning. I'm hoping that the AFR gauge helps shorten that process. Where did you mount the sensor for the AFR gauge?
Posts: 116 Likes: 2
I had the bung welded in at the collector before I shipped it to Jet-Hot ![[Linked Image]](https://tm-img.com/images/2023/01/23/Finished-header.jpeg)
Roger that. Our Kent 1600 has a four-into-one header but I'll be putting it in a similar spot, a couple of inches downstream of the collector...
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
Which sensor do you use for the AFR setting?
Clemens
PlusFour Red Baron MY 2022
Posts: 116 Likes: 2
CL, I bought an Innovate Motorsports MTX-L Plus AFR gauge. According to their documentation, the O2 sensor is a Bosch LSU 4.9 wideband sensor.
Good choice the wideband sensors from Bosch I know from my Harleys
Clemens
