5 members (Sumo, TBM, Ruut Bianchi, Gonze, TalkMorgan), 245 guests, and 159 robots.
+8Rich 101
John V6 66
2001 +8 Temperature gauge
by AlanB - 16/09/26 07:39 PM
Longest owner?
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,921
Posts838,285
Smed., Spanner Juggler
Page 22 of 165 1 2 20 21 22 23 24 164 165
He's hibernating...bit of warm weather and a run out in the Mog and Mr Squeak will return, I've been chasing one down for over four years frown
As it is wet & windy I cleaned & conditioned the leather. I just love that gliptone smell.
This pm I'll treat Belle to gonig over with utlimate detailer. A good way to avoid spending the afternoon listening to swmbo & swmbo Snr .
Put her into her winter storage container. Projects start tomorrow. Next year she will have her own dedicated garage.
After a couple of months of futzing around with replacing the fuel lines, adding an electric pump and filter/regulator, and sending my header out for reconditioning and ceramic coating, I finally heard my car running with Weber carbs today. I had a couple of missteps, but sorted them out after a bit of head scratching. The next step is to start fussing with the tuning. I'm hoping that the AFR gauge helps shorten that process.
Where did you mount the sensor for the AFR gauge?
I had the bung welded in at the collector before I shipped it to Jet-Hot
Roger that. Our Kent 1600 has a four-into-one header but I'll be putting it in a similar spot, a couple of inches downstream of the collector...
Which sensor do you use for the AFR setting?
Clemens
PlusFour Red Baron MY 2022
CL, I bought an Innovate Motorsports MTX-L Plus AFR gauge. According to their documentation, the O2 sensor is a Bosch LSU 4.9 wideband sensor.
Good choice the wideband sensors from Bosch I know from my Harleys
Clemens
