1 members (DavidR),
398
Topics49,897
Posts838,017
Posts: 116 Likes: 2
Posts: 116 Likes: 2 |
Paul, if you are going to keep your car in a container for the winter, you should consider adding a couple of small well-screened vents and a solar-powered fan. Condensation can get pretty heavy inside without ventilation.
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
Paul, if you are going to keep your car in a container for the winter, you should consider adding a couple of small well-screened vents and a solar-powered fan. Condensation can get pretty heavy inside without ventilation. I'll be working on the car over the winter, so it will be opened up at least 2 or 3 times a week. I have a small radiant heater that I run while I'm in there and the car is covered when I leave.
Posts: 6,675 Likes: 441
Posts: 6,675 Likes: 441 |
Cheeky little run out to Beckworth Emporium for a breakfast and a mooch round all the foo-foo stuff. Old girl didn't want to start - solenoid was just clicking. Originally thought battery (although kept on a smart charger) but same with a jump from the Mrs. Gave the starter a couple of taps with a hammer and she sprang into life. Ran nicely there and back, but didn't got too far as low on fuel and it's not payday till Tuesday........ ![[Linked Image]](https://www.tm-img.com/images/2023/01/29/IMG_20230129_100808_edit_827751340894006.md.jpeg)
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
Cheeky little run out to Beckworth Emporium for a breakfast and a mooch round all the foo-foo stuff. Old girl didn't want to start - solenoid was just clicking. Originally thought battery (although kept on a smart charger) but same with a jump from the Mrs. Gave the starter a couple of taps with a hammer and she sprang into life. Ran nicely there and back, but didn't got too far as low on fuel and it's not payday till Tuesday........ ![[Linked Image]](https://www.tm-img.com/images/2023/01/29/IMG_20230129_100808_edit_827751340894006.md.jpeg) A mechanic might have charged you £50 for that…50p for the hit with the hammer and £49.50 for knowing exactly where to hit it! 🥴
Posts: 5,468 Likes: 172
Posts: 5,468 Likes: 172 |
The old starter motor brushes on the way out so hit it trick.
/Thread drift alert
I once had a 1967 Mk2 Cortina (1500, pre crossflow) with this problem. A krook-lok was the best tool to hit the starter motor with in that instance. It took me a few weeks to get around to putting new brushes in the starter motor and the poor old crook-lok took quite a beating. Months later, when the Cortina had departed the way of all things that rusted in those days, I had replaced it with a Mk3 Triumph Spitfire. One sunny day, Mrs F & I went to visit an NT property. The krook-lok seized solid. I didn't have a hack saw in the boot - only a fine finishing file. It took 30 minutes to file through the krook-lok in a busy car park. Not one person challenged us. It could have been because the Spitfire, at that time, wasn't exactly pristine!
/End drift
Posts: 68 |
Decided the weather was just about good enough to head out for a drive today, for the first time this year. Only a few minutes drizzle up in the Lakes, so I just kept going. The roads were very quiet, being out of season. Was really nice to back behind the wheel again - a month seems too long without a "fix!" Photo is near south end of Coniston Water. ![[Linked Image]](https://www.tm-img.com/images/2023/01/30/Coniston-30-Jan-2023.jpeg)
Keith 2017 Plus 4, deep blue
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
Yep I cracked yesterday. The roads were dry , the sun was shining so a fast blast to the sea front. The wind of the N Sea was a tad cold though.
Posts: 8,696 Likes: 416
Posts: 8,696 Likes: 416 |
Ditto, took Morton to local nature reserve at East Wreatham to walk the dog. Started fine after 4 weeks lay up.
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
Nice fresh blow-away-the-cobwebs drive through the Suffolk countryside to Darsham to fill up ready for the St SWMBO's day drive out and lunch tomorrow. ![[Linked Image]](https://www.tm-img.com/images/2023/01/31/IMG_2967.md.jpeg)
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Posts: 2,125 Likes: 37
Posts: 2,125 Likes: 37 |
Bright & sunny day down here in Kent, so a quick blast round the local roads. First time out since the BHM Christmas Party on 10 December.
Regards Alan AP08 MOG 2016 Plus 4 GDi - Mazda Soul Red Metallic
