Topics49,914
Posts838,181
Posts: 5,469 Likes: 172
Posts: 5,469 Likes: 172 |
The past 2 services on our 4/4 have flagged a very slight coolant leak from the thermostat housing. I decided that a mild afternoon in January was the ideal time to fix this. Parts ordered and delivered, I set to straight after lunch on Monday. Dismantling was straightforward. The thermostat housing is fitted underneath the alternator on our 2014 car - and just above the engine mounting. The two hoses were OK to remove from underneath with the car on axle stands. I placed a container under the hoses and caught most of the coolant that escaped. Working from the side of the car, with a 1/4" drive socket set and a long extension I was able to remove the 4 set screws quite easily. The thermostat housing then pulled away and it was easy to spot the problem. There is a small gasket on the smaller of the two pipes and the thermostat housing has a rubber ring which acts as the other gasket. I replaced the thermostat housing and the thermostat. Looking at Ford forums, these plastic thermostat housings are prone to cracking. Best to consider them as consumables. Re-assembly got me flummoxed for a while. I ran out of time on Monday as it soon became time to get the horses in. The problem was that I could not hold the thermostat housing in place and insert one of the 4 set screws at the same time. I used rubber grease (red) to coat the two rubber gaskets and to hold the new thermostat in place. The thermostat is on the side of the engine so I ensured that the small pimple (bypass thingy?) was in the same orientation as on the thermostat that I removed. This afternoon, I finished the job. In order to get the thermostat housing ti stay in place, I cut the head off an M6 set screw and then cut a slot in the end. I was able to get the resulting threaded bar started in one of the fixing holes using some gaffer tape and a length of electric cable. Then the thermostat housing stayed in place long enough to get one of the other set screws started. A dab of grease in the socket held the set screw in place so that I could feed it past the assorted pipes, wires etc. Once all three other set screws were in place, I unscrewed my makeshift dowel and replaced it with the set screw. Torque settings for the M6 set screws (from a Ford forum) are 9Nm / 7 lb ft (I had to buy a new small torque wrench too!). Once all was back together, I refilled with coolant and ran the engine until the thermostat opened. So far so good. No time for a test drive today - getting the horses in intervened. Old thermostat housing showing tell-tale seepage & 2 rubber gaskets. ![[Linked Image]](https://tm-img.com/images/2023/02/01/9F9B2997-C611-4B4C-B804-5FC5D20A0B30.jpeg) Old thermostat housing showing 2 pipes - this is upside down compared to the orientation on the engine. Not sure where they crack though. ![[Linked Image]](https://tm-img.com/images/2023/02/01/5A45830B-600F-4AD0-AA42-9A2D7E9F7B51.jpeg) The answer to my inability to get any screws started. ![[Linked Image]](https://tm-img.com/images/2023/02/01/8154D88C-7EB7-4237-A034-E4B19B6F73FB.jpeg) ![[Linked Image]](https://tm-img.com/images/2023/02/01/7F34F531-BAB1-4D30-AF6D-D92A8F7FDE83.jpeg)
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Good job well done Paul 👌
Craig Jezz
Posts: 8,703 Likes: 416
Posts: 8,703 Likes: 416 |
+1 Paul  Would just add that to avoid coolant loss when removing hoses you could use radiator drain to allow some out first in a controlled manner. OE plastic rad drain shown below. ![[Linked Image]](https://i.imgur.com/CQwe1X2.jpg)
Posts: 793 Likes: 144
Posts: 793 Likes: 144 |
+2 Paul A well thought through solution 👍
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
Thanks Richard re draining. I was a bit too hasty and didn’t spot the drain on the rad until I was underneath re-fixing the hoses. Simon SiFab will cringe given that he thought to include the drain.
Also, I forgot to include the part numbers:
Housing = Ford part number 1707050
Thermostat = 1712228
Got them from the Ford eBay shop. £31.23 for the thermostat and £38.99 for the housing.
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Good job, Paul👍 Have you had a look which degrees celsius your new (and old) T are? should perhaps be engraved on the T. If I recall it right, somewhere around 82C?
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
+1 Paul  Would just add that to avoid coolant loss when removing hoses you could use radiator drain to allow some out first in a controlled manner. OE plastic rad drain shown below. ![[Linked Image]](https://i.imgur.com/CQwe1X2.jpg) When I went to undo the plastic drain plug on my old plastic radiator for a routine coolant change, it sheared in half along the threaded part, making me wish I had simply pulled a hose off instead! So I replaced the whole radiator with a Si fab one. Incidentally, I would have thought it just as well to replace the coolant on a 2014 car when doing a job like this, unless its been changed previously since new.
Good job, Paul👍 Have you had a look which degrees celsius your new (and old) T are? should perhaps be engraved on the T. If I recall it right, somewhere around 82C? Sorry Heinz, I haven't checked either. The annoying thing is that that old thermostat seemed fine but the rubber "gasket" had degraded. When I ran the engine up to temperature, the opening seemed to be the same as before.
Good point but changed when the radiator was changed.
Good job, Paul👍 Have you had a look which degrees celsius your new (and old) T are? should perhaps be engraved on the T. If I recall it right, somewhere around 82C? Sorry Heinz, I haven't checked either. The annoying thing is that that old thermostat seemed fine but the rubber "gasket" had degraded. When I ran the engine up to temperature, the opening seemed to be the same as before. Thanks to your part number I was able to google it, I hadn't thought of it at first. I just wanted to compare if I had bought the right thermostat three years ago. Yes, 82 degrees is what I also bought and it matches your part number.
