Morgan Aero 8
1 members (GrumpyPa), 147 guests, and 33 robots.
+8Rich 101
John V6 66
2001 +8 Temperature gauge
by AlanB - 16/09/26 07:39 PM
Longest owner?
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,921
Posts838,290
AshleyC, BobtheTrain, pandy, RobertMorgan, shaleafe
Page 3 of 4 1 2 3 4
Viper #769396 16/02/23 10:37 AM
Over here as long as it passes the MOT every year (inspection) then you’re fine.
Most of these cars will pass that emissions check with one cat and some heat - so make sure you drive hard on the way to the test and get the cat hot 😁
Current - 2013 Plus 8
Previous - 2002 Aero 8 S1, chassis number 96 - Ragusa Green Metallic
Viper #769399 16/02/23 12:59 PM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
I think now though if an MOT tester sees that a CAT has been deleted then it’s a fail
2002 Aero 8 S1
2023 Plus 4 (woman’s)
Viper #769414 16/02/23 04:54 PM
Smile, it confuses them
I am aware of people who de-cat new cars as they have the three year period (soon to be four if you follow the gov's recent crap review of the MoT process) and enjoy the additional fun. Given the rules around car exhaust volume now in place it needs something to provide aural enjoyment. How the Aero dual sidepipes ever pass is a mystery to me.
Once into MoT they are getting very fussy now. A couple of GTR owners I speak to have a section of the exhaust made up where the cat has been removed. Each year prior to the MoT they slip the cat back in and take the test. Once approved it comes back off and the blank is fitted again. The engine map is selected for no CAT and the thing sounds just naughty. One did try and get buy with a hot engine and tight engine map but it was failed.
Viper #769419 16/02/23 07:38 PM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
Everyone needs a friendly MOT man
2002 Aero 8 S1
Viper #769515 18/02/23 10:39 AM
The replacement bypass pipe is a good option if you don't have a friendly tester, or 4 sports cats I guess but that seems expensive..
I guess they other way round is to just bash out the insides of one and then you don't need any new bits, and visually it looks the same. cheers
Aero 8 GTN #11
Viper #769550 18/02/23 04:51 PM
I was never a very good mechanic a lifetime ago but here goes. Don't bash the insides out, if you must take the box off cut with a grinder from the middle out so you can see the baffles then access the box and remove the plates carefully when the box is empty weld a plate back to the box. This is best done on the top of the box so when it is re fitted it still looks stock from the underneath.Be aware your engine may run a little leaner and therefore hotter whip your plugs out after a tank full and you should have your answer. Personally if you have sports cats and a sports exhaust I would leave well alone but we all have choices.It will sound good though...
Viper #769552 18/02/23 05:10 PM
Also if its a stainless exhaust weld back a stainless plate back on unless you did a good job with the grinder so the original might just fit.
Viper #769560 18/02/23 06:09 PM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
I’m not going to cut or bash an existing CAT just in case it needs to go back on.
An MOT tester can’t see anything untoward as it’s all hidden on an aero
2002 Aero 8 S1
Viper #769562 18/02/23 06:20 PM
Sorry Viper should have read the post more closely I thought Nick was talking about the box not the cat. My cat was clearly visible from under the car well half of it was...,
Viper #770542 04/03/23 12:45 PM
So have you done it yet.. innocent
Aero 8 GTN #11
Page 3 of 4 1 2 3 4
