3 members (RalfL, Alan Patterson, JohnHarris), 254 guests, and 42 robots.
+8Rich 103
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,917
Posts838,230
MossyfromNZ
Page 27 of 165 1 2 25 26 27 28 29 164 165
Refurbished my steering wheel.
It's been on my to do list for a while, previous owner had scrapped off quite a lot of varnish around the rim, probably on a belt buckle. Now sanded, stained and 1st coat of varnish applied, looking much better.
Mark
2015 +4 Ferrari Le Mans Blue
T-Track 2 are imho a very good decision.
I am curious what your assessment will be!?
Road tested the new T Trac 2 tyres this afternoon, really grip well (without screeching) compared to the old Continentals.
Thanks to RobCol on here for recommending them thumbs
Craig Jezz
1 member likes this: Robert MB
I’ve been prepping the Mog for it’s Control Technique which is due the end of this month; brakes stripped, cleaned and inspected, a wizz round with the grease gun, cross head stays, bumper brackets and wings stays removed, stripped and repainted (I know, they’re just cosmetic!), front indicators stripped, de rusted (again) and all lights checked, this week I’ll change the oil and filter and have a run out if work allows.
Mike H
Bourgogne Franche Comté
Jacked the car up to have a look for anything causing the annoying rattle I have. Iund a couple of loose bolts securing the front under tray. Gave them a rattle and from the sound I think I've found the problem. Have the underneath of the duff a good going over with some acf50. As can be seen from the below pictures, my prop shaft nipples were on show so gave the from 2 a couple of squirts each. Don't think I got anything in to the rear one as there was quite a bit of resistance, and didn't want to force it. Is this resistance normal?
2004 Series 1 Roadster
Leroy, sometimes if the nipple hasn't been used for a while the tiny ball that you just see part of (acts as a sort of spring loaded no-return valve) can jam shut, before applying the 'gun' just depress with the end of a small screwdriver & re-grease
Agreed and propshaft nipples are often overlooked especially at the front
Great advice, I'll give that a go next time it's in the air.
I was really pleased both the front ones were accessible, and pointing in the right direction.
Black Rat
Black Rat
I do like it when the nipples are accessible and pointing in my direction pantsdown
Keith
2013 narrow bodied + 4 Ruby.
rofl
