8 members (Image, RichardV6, Graham, G4FUJ, sewin, Dinko, B3MOG, James B W, Strathaven), 250 guests, and 21 robots.
+8Rich 99
John V6 55
Topics49,908
Posts838,114
I started out at 3/3 with my AVO's, but two up it would still bottom out at the rear when booting it on an uneven road, so now I'm on 4/4 clicks.
Miller's have just fitted Cerealsurfers secondhand Sapx shock I bought on TM. All I can say is they are big improvement over my old Konis.
John V6 #110949 09/11/12 04:38 PM
John - What type of difference?
A11OGE #110950 09/11/12 04:42 PM
Much smoother in general with far less bottom out of the shock.
Chris Hoddo #769025 09/02/23 08:47 PM
I have Avo front shocks which I fitted in 2013 and have now done 20k. I notice oil misting around the shock tube. Is this a sign of them failing? Is there a way to tell if they need replaced or not? They are Avo (Rutherford by New Elms)
Thanks in advance
Will
Chris Hoddo #769026 09/02/23 09:04 PM
Online NoMood
Sounds like they are starting to fail Will. Do they still work and respond to increased setting?
Chris Hoddo #769027 09/02/23 09:28 PM
I haven’t changed the setting since I fitted them.. what’s optimal?
Chris Hoddo #769028 09/02/23 10:03 PM
Online NoMood
On mine tweaking them up a couple of clicks at a time then driving on a similar stretch of road I found a point where the front stopped moving up and down so much. For the first few hundred yards it seemed the suspension had become too firm but then after a mile or two I realised the ride was actually more comfortable because of such. I called it the sweet spot as it was so well defined. You can always back off a click or two to prove the point. YMMV
Chris Hoddo #769046 10/02/23 11:41 AM
Black Rat
Black Rat
You can get them refurbished I believe.
Keith
2013 narrow bodied + 4 Ruby.
Chris Hoddo #769048 10/02/23 11:56 AM
TBM Offline
You can (they're just up the road from me)
https://www.avouk.com/services/
