Posts837,989
Posts: 1,341 Likes: 15
Posts: 1,341 Likes: 15 |
Dear Will or The Customer,
yes the original Z8 steering wheel has an airbag and yes the Z8 steering wheel in the Aeromax has an airbag as well.
Regards Frank fascinating - thanks Frank Will
Formerly Aero S5 #80 Currently 911 (992) Targa in python green
Posts: 3,439 Likes: 7
Goodwood Drifter Talk Morgan Addict
Posts: 3,439 Likes: 7 |
a Coupe is way cooler than an Aeromax but that split-window design and the story of the Prince and... make the 'Max so special
Steven sold: M3W, Aeromax,V6, 4/4 4seater now: +fourLM62
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Here is a RHD Aero Series 1 in Germany. Of course you don't know much without inspection, test drive and history, but the price seems attractive if the car is ok. It looks like a normal dealer for slightly better everyday cars who would rather make a quick turnover than charge a top price. https://suchen.mobile.de/fahrzeuge/...-cb7a-c9a2-90ea-8fb59eebcac4&ref=srp
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
- unusual rear diffuser on there too Heinz; looks as though it could be a 'one off ' design.... James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Looks more like a cheap sheet metal trim. For the exhaust system, I don't know if only one pipe per side was original on the early Aeros. As I said, one would have to look at it in the metal.
Posts: 1,508 Likes: 57
Posts: 1,508 Likes: 57 |
Do you know if the Z8 wheel had an airbag? If I recall right the Z8 has a 2 stages airbag, while the original Raid steering wheel has a 1 stage ones. That means, for instance, that in CH you would need some very good friend, to have it registered for the MFK (MOT). Technically the change is doable, though.
Posts: 1,079 Likes: 71
Posts: 1,079 Likes: 71 |
Looks more like a cheap sheet metal trim. For the exhaust system, I don't know if only one pipe per side was original on the early Aeros. As I said, one would have to look at it in the metal. Yes Heinz, single pipes either side was the usual choice, this one looks like it's had the Librands Sports 4 outlet system fitted.
David Aero S4
